Making Weld Beads, an MSW SBS
Crew-mate Glenn Cauley shares his technique and tool-making for realistic weld beads, in this MSW SBS (Step-by-Step) feature!
Here is an explanation of one of the more useful tools and techniques that I accidentally discovered while adding weld beads to my U‑673 boat.
I needed to create realistic-looking weld beads on the hull of my U‑boat...I did not want to use putty since it is not well suited to this task, and is fairly difficult to get consistent results. I needed to find something quick and most of all... easy.
STEP 1: Adding the Basic Welds
Cement strips of flat strip styrene (I used 0.010 x 0.020" flat strip styrene from Evergreen), to the model using liquid cement (I use Tenax-7R liquid cement).
Sand the strips so they are very thin.
How too......
Copyright ©2021 by Glenn Cauley. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-12-23 00:00:00. Unique Reads: 11240
