U 84, Type VIIB Submarine
Post a Comment
"MSW crew-mate Bob Cicconi (bobcicconi) shares a gallery of images of a late conversion build of his, VII B Submarine, U 84, in this "On Display" feature!"
Type-VIIB
Ordered-9 Jun, 1938
Laid down-9 Nov, 1939 Flender-Werke, Lübeck (werk 280)
Launched-26 Feb, 1941
Commissioned-29 Apr, 1941-Oblt. Horst Uphoff
Commanders-29 Apr, 1941 - 7 Aug, 1943-Kptlt. Horst Uphoff
Career-8 patrols-29 Apr, 1941 - 31 Aug, 1941 1. Flottille (training)
1 Sep, 1941 - 7 Aug, 1943 1. Flottille (front boat)
Successes-6 ships sunk for a total of 29.905 GRT
1 ship damaged for a total of 7.176 GRT
Fate-Sunk on 7 Aug, 1943 in the North Atlantic, in position 27.55N, 68.03W, by a Mk 24 homing torpedo from an American Liberator aircraft (VB-105/B-4 USN). 46 dead (all hands lost).
The 88mm deck gun barrel, 20mm barrels, and pedestals were turned on a lathe. Extensive modification to the original kit was done, including drilling out the limber holes, grinding off the molded rails and ladders and substituting brass rod, and adding the loop antenna on the starboard side of the tower.
Two Nautilus photo etch kits were used, as was an AMP (Accurate Model Parts) flag that was made specifically for this build. Rigging was .004 dai riki line. Floquil and Testors paints were used as well as Alclad pale gold for the propellers. Keith Bender made the pedestals, mounting base, and cover for me. It was a lot of work, as the U-99 is an old kit, but I was happy with the results!
the vessel
Type-VIIB
Ordered-9 Jun, 1938
the model...
This sub model was modified from the 1:125 Revell U-99 kit. The aft platform, 20mm gun assemblies including pedestals, platform and conning tower decks, and nav lights were all scratchbuilt.The 88mm deck gun barrel, 20mm barrels, and pedestals were turned on a lathe. Extensive modification to the original kit was done, including drilling out the limber holes, grinding off the molded rails and ladders and substituting brass rod, and adding the loop antenna on the starboard side of the tower.
Copyright ©2021 by Bob Cicconi. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-08-21 00:00:00. Unique Reads: 5917
