1⁄35Italeri 1/35 Vosper 72'6
Warren's Vosper...
Hello Everyone,I have been a participant in the Channel Adversaries build and have finally finished the kit. Well mostly finished I still haven't worked out how to make the red duster look realistic so it can stay off for the moment.
The kit is Italeri's 1/35 Vosper MTB. I also used Griffon's N35001 Basic Detail-Upgraded Set and scratch-built quite a bit of stuff as well, including radar aerials and stuff in the cabin you can't see anymore. Also incorporated were 1 mm diameter resin bolts and washers from Masterclub used on the bases of the torpedo tubes. Here are some photos for your viewing pleasure (I hope!)
Cheers Warren
Copyright ©2021 by Warren Inman. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2013-10-16 00:00:00. Unique Reads: 10367
