Hi Si,
that's a very nice touch to your build log, that you're doing the other one for comparison!! Quite some changes there on the after structure! -I had some sources showing the changes, but somehow I decided to ignore them (I didn't know about the Admiralty kit then); now I remember: at the time I decided it was too complex to scratch with just a few pictures... That's really an improvement!!
Very nice process on the hull and the deck/vents!!
HMS Repulse May 1941
Posted: Sunday, April 10, 2016 - 09:39 AM UTC
Posted: Sunday, April 10, 2016 - 04:11 PM UTC
Racing along Si! Looks great!
Posted: Sunday, April 10, 2016 - 05:07 PM UTC
Hi Jan,
Thank you, The after superstructures are so different I thought it was worth it. The Admiralty upgrade is a very good , the changes to the after superstructure certainly match the limited drawings I have, and like you I would not have liked to have tried a scratchbuild from those.
The vents re fun, there rather a lot of them too, but from a painting and accuracy point of view, much better than moulded in with the deck.
Posted: Sunday, April 10, 2016 - 05:10 PM UTC
Thanks Russ,
Wait till I get onto the detail stuff, including more more etch, that will slow me down a bit.
Sundays update still to post, will try to get that done tonight.
Posted: Sunday, April 10, 2016 - 11:49 PM UTC
Sunday's progress.
The first two life rafts are required, the GMM set provided etch for the bottoms.
Funnels, and some superstructure units assembled. This ship has quite a complex superstructure, this isn't the half of it.
First ladder folded and test fitted.
Details going on the lower main superstructure deck, location for tha after funnel has been painted black as the after funnel is see through.
New sections sprayed, funnel cap painted and test fitted.
A quick overview of the whole project so far. Looks a lot further on than it really is. lots of detail work on these bits to do yet.
One thing I did notice looking at this picture, the 20mm tubs on either side of where the conning tower will go need removing before any more progress on that.
Posted: Monday, April 11, 2016 - 02:48 AM UTC
Wow Si, rapid perfection as always mate.
Posted: Monday, April 11, 2016 - 09:40 AM UTC
Well - what Russ said!! Rapid perfection - good way to put it
Very nice progress there, superstructure is coming along very nicely!!
You are right about the 20mm tubs forward, they need to go, the guns don't fit. To my knowledge, there actually were guns, but the tubs are wrong shaped.
The four holes, two either side, on the same level, need to be closed I think - they were intended for saluting guns, that weren't carried in late '41. I am not sure about early '41 I have to admit. Apparently there were a couple wooden benches installed in '36 for the dignitaries to hang out. No idea about '41 though, I omitted them...
Posted: Monday, April 11, 2016 - 05:20 PM UTC
Hi Russ,
Thanks Mate, all straight forward stuff in that lot. I promise to slow down when I get on to all heavy etch stuff.
Posted: Monday, April 11, 2016 - 05:28 PM UTC
Thanks Jan,
May well have missed the removal of the saluting guns.
Some of the drawings I have seem to suffer from a little uncertainty on exactly what date they represent the ship.
I am not exactly sure if she had any 20mm at that time, R&R show refers to eight singles being added "mid 1941" I am presuming that was after the Bismarck chase, the Kit shows her with about a dozen, so either four were fitted prior the Bismarck chase or one of the two are wrong?
More research needed.
Posted: Saturday, April 16, 2016 - 12:04 AM UTC
TRM5150
Posted: Saturday, April 16, 2016 - 02:48 PM UTC
That's some work in itself to get that cleaned smooth my friend! Every little bit gets you that much closer!!
Posted: Saturday, April 16, 2016 - 10:12 PM UTC
Thanks Todd,
I find sanding quite therapeutic sometimes. Proper update later today or tomorrow.
Posted: Sunday, April 17, 2016 - 02:43 AM UTC
Proper update today.
The first two liferafts with paddles and lashings fitted.
structure fitted under the after section of the upper main superstructure deck.
Moulded on boat chocks removed.
Underdeck supports fitted to the upper level of the after superstructure, and sprayed.
Upper deck sections fitted, still need a coat of dark grey, all the gun supports also in place.
Liferafts also fitted.
Basic assembly on the four boats that alongside the hangers. These come from the Admiralty upgrade set, they still need rudders and oars etc. adding. The boat craddles will come from the WEM set.
Overview of the ship as she stands.
More soon,
More soon,
Posted: Sunday, April 17, 2016 - 02:55 AM UTC
a mighty fine 'overview' Si
shaping up very nicely.
Posted: Sunday, April 17, 2016 - 09:08 AM UTC
Very nice update, Si!
Quite some progress on all the various parts of the superstructure - that's quite a complex on on good Repulse, but it gives the ship it's distinctive look! Nice work!
- and a great job on the life rafts/floats! They'll stand out!! Not to forget, the Admiralty kit's parts - the boats look like e real improvement over the kit's part!!
Looking forward to see her grow!!
Posted: Sunday, April 17, 2016 - 11:45 AM UTC
Hi Russ,
Thanks mate, she is getting there slowly but surely.
Posted: Sunday, April 17, 2016 - 11:48 AM UTC
Hi Jan,
I think it must rate as the most complex superstructure I have come across.
Very interesting to build.
Bit od touching up to do around the front gun support before a few sections of railing do on.
Posted: Saturday, April 23, 2016 - 01:43 AM UTC
TRM5150
Posted: Saturday, April 23, 2016 - 06:49 AM UTC
SOme nice work in a tight space Si! Launches look super in place!
Posted: Saturday, April 23, 2016 - 04:35 PM UTC
Very nice work here as well, Si!!
The superstructure is coming along nicely! Looks really good!!
Posted: Saturday, April 23, 2016 - 09:27 PM UTC
Thanks Todd,
It is the fun of the these rebuilt WW1 vessels, the layout tends to be a bit "interesting.
Posted: Saturday, April 23, 2016 - 09:29 PM UTC
Thanks Jan,
It is getting there, still lots to do though.
Intend to try and tuck a Walrus on one Hanger, since WEM give nice etched hanger doors.
Posted: Saturday, April 23, 2016 - 10:31 PM UTC
I did like the WEM hangar doors very much for my build, they add depth to that area.
I don't know what I did wrong - or if anything - however, the Walrus would not fit through the hangar door (see my Belfast - same thing). The dimensions of the Walrus seem to be spot on though... Would be interesting to see if you find out what's wrong there...
Posted: Sunday, April 24, 2016 - 01:48 AM UTC
Interesting, I will have a try, need to have a look at what I have got on Walrus wing folds.
Could be the external dimensions of the hanger are correct, but that would make the internal dimensions a little narrow.
Hope to get some time in the workshop over the long weekend net weekend.
Posted: Sunday, May 01, 2016 - 01:10 AM UTC
A bit more progress,
Quarterdeck details on.
Slight fit problem caused by accommodation ladder davits.
Just turned it through 180 degrees, job done.
Parts for the two Walrus's.
Not a fan of clear aircraft, so misted some dark grey on, and nasty moulded on struts removed.
Etch going on No.1 Walrus. Neither WEM or GMM provided engine mounts, so making those up as I go along.
Superstructure glued down and details added.
More soon
More soon
