DKM BISMARCK 1941 – 1/200 - Trumpeter, Pontos
elmarriachi
Baden-Württemberg, Germany
KitMaker: 813 posts
Model Shipwrights: 304 posts
Posted: Saturday, October 10, 2015 - 10:31 PM UTC
*** UPDATE ***
The main mast.... painted ... finished.... not yet washed... not yet details painted...... but mounted ....
The first of the two cranes..... modified jib, added turned brass parts. ..... added etched parts.... .and jib glued in correct high .....
Anchor chain.... 3D print... black painted..... several washes with oil colors in rust ..... glued in place... maybe one anchoer will lay on the wooden base of the display... to show something more of the great looking chaing ......
Micha
RussellE
KitMaker: 3,133 posts
Posted: Sunday, October 11, 2015 - 08:18 AM UTC
better 'n better, Michael
KitMaker: 6,486 posts
Posted: Sunday, October 11, 2015 - 11:59 PM UTC
Hi Michael
What Russ said, great build, following with interest.
Cheers.
rolltide31
#377
KitMaker: 1,383 posts
Model Shipwrights: 1,234 posts
Posted: Monday, October 12, 2015 - 05:39 AM UTC
Michael,
Incredible work. Your work continues to amaze
elmarriachi
KitMaker: 813 posts
Posted: Monday, October 12, 2015 - 01:47 PM UTC
Thank you very much!
I am working on the 2nd crane right now.... then the railings on the rear super structure will follow.... then I will start with the armament of the ship ....
surfsup
KitMaker: 1,144 posts
Model Shipwrights: 1,126 posts
Posted: Monday, October 12, 2015 - 04:26 PM UTC
Just simply superb.....Cheers mark
JJ1973
#345
KitMaker: 1,690 posts
Posted: Friday, October 23, 2015 - 11:00 PM UTC
Micha,
this is just fantastic work, simply awesome...looking for words...
Thanks for sharing this fantastic build - I can't wait for your next update...great!
elmarriachi
KitMaker: 813 posts
Posted: Saturday, October 24, 2015 - 11:34 PM UTC
*** UPDATE ***
the first small guns are finished..... without changes from the Trumpeter kit, only with pontos gun barrels ...
Micha
JJ1973
#345
Posted: Saturday, October 24, 2015 - 11:47 PM UTC
Looking good here, as well!! I do like the look of this 4.1" AA guns, even though apparently they have been not all that effective...
elmarriachi
KitMaker: 813 posts
Posted: Saturday, October 31, 2015 - 11:06 PM UTC
*** UPDATE ***
The main turrets, Anton and Berta are finished. Both received some metal gun barrels from Pontos, some range finders from CMK (resin parts with interior parts and etched hatches), and several photo etched parts for further detatils... the turrets Cäsar and Dora will follow in the same way ...
Micha
Posted: Sunday, November 01, 2015 - 03:35 AM UTC
Nice progress on the armament Michael,
The Main turrets look good sat on their barbettes.
Cheers.
surfsup
Posted: Sunday, November 01, 2015 - 04:13 PM UTC
The Details on the Turrets is looking great.....Cheers mark
RussellE
Posted: Monday, November 02, 2015 - 03:32 PM UTC
Nice Turrets Micheal
elmarriachi
KitMaker: 813 posts
Posted: Thursday, November 05, 2015 - 06:29 PM UTC
*** UPDATE ***
The 38-cm turrets (SK C/34) - "Anton", "Berta", "Cäsar" und "Dora"
The kit parts are mounted, the gun barrels from pontos added. The rangefinders are resin-parts from CMK with ethced hadges. The blast bags are resin parts from Pontos. Then the small etched parts were mounted to each turret...
The 15-cm turrets (SK C/28) - 3 on both ship-sides
These are mounted and also the gun barrels and blast bags from Pontos added. The range finders are also CMK with etched hadges. Several holes are drilled, then the steps on each side / backside are glued in place ...
The smaller flak 2cm L/65 C30 and C38
The smaller anti air guns are built 99% from phtoetched parts from the pontos set. Only few parts of the trumpeter kit were used.... everything else is built with etched parts, brass barrels ,....
CHEERS
Micha
TRM5150
Staff MemberEditor-in-Chief
MODEL SHIPWRIGHTS
KitMaker: 2,158 posts
Model Shipwrights: 1,399 posts
Posted: Friday, November 06, 2015 - 07:00 PM UTC
Another fine bit of work Michael! Clean work on the guns!
JJ1973
#345
Posted: Saturday, November 07, 2015 - 11:17 PM UTC
Micha,
very nice work again, your turrets look fantastic!
The little quad 20 mm and the army type single look quite stunning with almost all brass design! I'd figure that was some fiddly work...
Posted: Sunday, November 08, 2015 - 11:11 PM UTC
Very tidy work on the armament Michael.
The single 20mm look real little masterpieces.
Following with interest.
Cheers.
elmarriachi
KitMaker: 813 posts
Posted: Monday, November 09, 2015 - 01:51 AM UTC
Thank you very much @ all!
*** UPDATE ***
THE MAIN GUNS ARE COLORED .....
First all turrets and armory were airbrushed with valleyo black primer as a fist kind of shadow. Next light grey was airbrushed on all parts, still keeping the black primer shining through the grey.
After a masking session the dark areas were airbrushed in Nato Black, as well as the gun barrels - both also with airbrush.
The two turrets on each side left and right got a white area airbrushed in the same way as the stripes on the superstructure.
The smaller details were brush painted with a fine brush....
Then all the finished parts were mounted on the ship, still movable.....
Next step: Washing with oil colors in the same way as the other parts of the superstructure .....
rolltide31
#377
Posted: Monday, November 09, 2015 - 06:11 AM UTC
Michael,
What can I say, I am just in awe of your skill. He is an amazing example of artistic perfection. Looking forward to seeing how you weather him and seeing the final result.
JJ1973
#345
Posted: Monday, November 09, 2015 - 10:32 AM UTC
Micha,
that is absolutely astonishing great work!! Just sitting back and watching your latest pictures in some kind of awe...fantastic!!
No doubt, that's the best BISMARCK model I have seen so far!!
RussellE
Posted: Monday, November 09, 2015 - 02:39 PM UTC
Wow, Michael!
surfsup
Posted: Monday, November 09, 2015 - 06:37 PM UTC
elmarriachi
KitMaker: 813 posts
Posted: Thursday, November 12, 2015 - 03:18 PM UTC
Thank you very much ...
Now working on the smallest guns ...
Staff MemberAssociate Editor
MODEL SHIPWRIGHTS
KitMaker: 2,072 posts
Model Shipwrights: 1,520 posts
Posted: Thursday, November 12, 2015 - 10:40 PM UTC
Wow, Michael... stunning work on those main turrets!
Posted: Friday, November 13, 2015 - 09:06 PM UTC
Outstanding Michael.
The armament looks excellent painted and in place.
