Ships by Class/Type: Carriers
Hosted by Todd Michalak
USS Intrepid CV11 1944 -1/350 Scale
KitMaker: 6,131 posts
Model Shipwrights: 5,702 posts
Posted: Saturday, May 05, 2018 - 02:39 PM UTC
So as not to clog up the Flattops Campaign thread I will be putting a bit more detail on this build log of my Intrepid build.
The base kit is the Trumpeter USS Hornet.
with the Pontos upgrade.
Main reference is
So I should be able to capture the most of the differences between the two vessels.
Also I will be adding an extensive air wing, I accept it will be 100% correct, but it was what I could source, and quite a lot will be in the hanger.
Mould seams on the bow of the lower hull, and the stern of the upper section.
cleaned up.
The keel laid.
Not a bad fit at all, a little clean up needed,but not the half a tube filler.
The hanger decks test fitted, all good - Warspite is alongside for scale.
The forward elevator will be down, (along with the deck edge one) The after elevator will be up, since I am going to have the hanger side shutters open I creating a simplified well the elevator would sit in in the lowered position.
Chain drilling the well, the mould line for the postion was drawn in with fine marker pen so i could see what I was doing.
cut out, cleaned up,and given a bit of depth with plastic strip.
a plasticard floor added to the well, and the hanger deck section fitted in place.
The fo'c's'le section, with the bulkheads of the forward hanger well bulkeahd in place, bit of fettling needed here, and I need to be careful as this could throw out the fit of everything else.
Right I will of up into the workshop to try and fix that shorttly.
Test fitting the hanger deck section
RussellE
KitMaker: 2,703 posts
Model Shipwrights: 2,200 posts
Posted: Saturday, May 05, 2018 - 04:02 PM UTC
I'm onboard!
Cadeus
Indiana, United States
KitMaker: 143 posts
Model Shipwrights: 138 posts
Posted: Saturday, May 05, 2018 - 10:22 PM UTC
Good start si, following along
d6mst0
#453
KitMaker: 1,034 posts
Model Shipwrights: 571 posts
Posted: Saturday, May 05, 2018 - 11:08 PM UTC
Agree, you are off to a nice start. I like your idea of the rear aircraft lift being in a lower position. This will be most interesting to see how you outfit this one.
babaoriley
KitMaker: 152 posts
Model Shipwrights: 11 posts
Posted: Sunday, May 06, 2018 - 01:10 AM UTC
I've been aboard both those vessels (both long after they became museum ships) so the odds are that I'll try to build kits of them at some point, depending on the space available for display. Sadly my wife is now able to look at photos of PE and resin upgrade kits such as you posted and have a pretty good idea of the cost of the build. Usually some nice earrings will smooth over that situation.
Cosimodo
#335
KitMaker: 1,099 posts
Model Shipwrights: 788 posts
Posted: Sunday, May 06, 2018 - 12:26 PM UTC
Good start Si.
I think your right making sure the fit of the decks to the hull is spot on. I spent the weekend looking at the kit plans and etch plans to see what's required and so much brass is focused fore and aft under the flight deck that I think if the kit is not quite right then the problems will manifest themselves later.
I am glad your setting the path for others to follow.
Posted: Sunday, May 06, 2018 - 03:01 PM UTC
I'm onboard!
Welcome aboard Russ,
Always glad to have you along.
Posted: Sunday, May 06, 2018 - 03:02 PM UTC
Thanks Norman,
Glad to have you along for the ride.
Posted: Sunday, May 06, 2018 - 03:09 PM UTC
Hi Mark,
Welcome aboard, the plan is to have a strike ranged on deck, with more aircraft in the hangers. I will be adding extra detail to the hanger deck as I will removing most of the shutters that are moulded in place.
Posted: Sunday, May 06, 2018 - 03:21 PM UTC
Hi Doug,
I am a lttle jealous of that, I would love to visit these fine ships, it is convincing Mrs Duster that a trip round the US visiting Museum ships would be a good idea. Earrings, nice move, I will have to remember that next time I realise I have pushed my luck to far on the hobby spending.
Posted: Sunday, May 06, 2018 - 03:27 PM UTC
Good start Si.
Thanks Michael,
That is what was worrying me, too much fettling in the wrong place can throw everything out. I have a similar situation, all the structure at the from and rear of the flight deck is etched. Whether that will give more or less flexibility in it's only time will tell.
Good luck with build to mate.
Posted: Sunday, May 06, 2018 - 04:03 PM UTC
Yesterday's progress.
The foredeck fettled and sworn at till it fitted.
There is now a short tale, without words of filing and filing.
The prop shafts and rudder in place.
Finally, I need to make a single, offset 40mm tub on the stern, the twin mount supplied with the kit.
I am off of the workshop to start hacking it around to make a single.
More soon.
babaoriley
KitMaker: 152 posts
Posted: Sunday, May 06, 2018 - 10:55 PM UTC
Hi Doug,
This year I've managed to convince her a visit to San Diego to see the impressive collection of ships they have there, especially USS Midway and "HMS" Surprise, would be a great idea. That's going to mean a lot of earrings.
McRunty
#491
Missouri, United States
KitMaker: 277 posts
Model Shipwrights: 114 posts
Posted: Monday, May 07, 2018 - 01:11 AM UTC
Hi Doug,
I am working on it myself. So far I have been to 2 of the 7 BB's on display with a trip to the USS Alabama planned for July. Still, so many ships and so little time plus they are all far away. Not many ship Museums in Missouri
babaoriley
KitMaker: 152 posts
Posted: Monday, May 07, 2018 - 07:12 AM UTC
Hi Doug,
I managed to make it aboard the USS Iowa before it was towed from Richmond, Calif. (where it was being renovated) down to San Pedro will it is now a museum ship. It was sad to see it leave this area but San Francisco's board of supervisors made an idiotic political decision not to welcome the ship to San Francisco's waterfront. Standing beside those 16" guns was really something, made history come alive. Should I ever win the lottery I can see a world tour of historic ships, with my wide's approval of course.
Cosimodo
#335
Posted: Monday, May 07, 2018 - 11:06 AM UTC
I visited Intrepid when I was in New York a couple of years ago with my son. It doesn't bear much resemblance to the Intrepid Simon is building but it was pretty cool to have alook around the ship and the planes on deck.
Posted: Monday, May 07, 2018 - 11:03 PM UTC
Hi Doug,
I think that one will take more than earrings, I was allowed to visit the Wasa last time in Stockholm, which Mrs Duster did enjoy. I keep the hoping, maybe a retirement trip with a few other sites thrown in.
Posted: Monday, May 07, 2018 - 11:09 PM UTC
That is true Michael,
But I do have the angle deck Intrepid in the stash. (Would be useful to walk the deck before I build that one) I am now getting dumb idea of also converting one of the straight deck kits into a 27 Charlie. I need to go and have a lie down until the idea goes away!
Cadeus
KitMaker: 143 posts
Posted: Monday, May 07, 2018 - 11:36 PM UTC
Iím sure you could sell the US trip with some planned stops for her as well, also with as many modelers across the nation you could sell the idea of not paying for hotels and stay with fellow builders hahaha Iím sure she would love that idea. Donít feel bad though, I live in the Midwest, and still havenít found the time or funds to travel and see the museum ships. I have visited wright Patterson Air Force bade museum and it is impressive. To the build at hand, the speed in which you build still amazes me, in the time it takes you to post four kit updates Iíve managed to build 15 type 96 IJN AA guns. Keep it up, I love seeing aircraft carriers built, an art in all its own.
Posted: Monday, May 07, 2018 - 11:45 PM UTC
good in, and interesting chatting about all the great museum ships around the world, but back to business.
The single 40mm tub converted from the kit twin.
Fitted in place.
The underside structure under way.
The rough shape built out of plastic strip.
Rough coat of filler on.
sanded and a second coat on.
And the second coat sanded, ready for a coat of primer thence a final polish up.
The starboard quarter 40mm tubs are further inboard and the after one further forward on the Intrepid. The fwd of the pair is in the correct position and the after as provided in the kit.
Both tubs in the correct position. A little work to be done on the underside of both of them.
The port forward 40mm sponson in fitted in place.
The plan is to get a few more bits down and then get some paint on the hanger deck, before hacking the shutters out of the hanger sidewalls.
More soon.
Cosimodo
#335
Posted: Tuesday, May 08, 2018 - 11:11 AM UTC
Nice work on the gun tub and the rearrangements. Does the Pontos set not provide replacements for these or are these changes due to switching Yorktown to Intrepid.
MartinJQuinn
KitMaker: 553 posts
Model Shipwrights: 510 posts
Posted: Wednesday, May 09, 2018 - 04:29 AM UTC
FYI: the struts that support the shafts are "V" shaped, as seen in this photo from NavSource:
http://www.navsource.org/archives/02/021155b.jpg
TracyWhite
Washington, United States
KitMaker: 524 posts
Model Shipwrights: 461 posts
Posted: Wednesday, May 09, 2018 - 09:26 PM UTC
For what it's worth, this isn't a ship change as much as a time change. Both Yorktown and Intrepid had the single quad 40mm on the stern as launched and finished the war with the twin quad 40mm configuration by the end of the war. The Trumpeter CV-9 Essex kit contains the single tub pieces as it's more of an "as launched" configuration.
Posted: Wednesday, May 09, 2018 - 10:51 PM UTC
Hi Michael,
The Pontos set does not provide 40mm tub replacements, it provide ammo racks for them and some variations for the 20mm fittings, it is really designed to fit the Yorktown kit as provided. Also some variety in radar too, which will make the conversion easier.
Thanks for looking in.
Posted: Wednesday, May 09, 2018 - 10:55 PM UTC
Thanks for the info Martin,
At least it will be an easyish fix, on the list for this weekend's time in the workshop.
