1⁄72Scuttled!
17
Crew mate Robert Scott (smokin_guns3) shares a photo gallery of one of his latest builds, German U-boat Type VII C, "Scuttled ".
The model used is the Revell of Germany first issue of the Type VII C U-Boat, 1/72 scale. Roberts weathering methods used are quite interesting...The built model was first given a wash of Rustall, and then a heavy coat of Future (floor wax).
I then sprinkled fine dirt over the entire model while the Future was still tacky...once dry I gave it another coat of Rustall, but didn’t like the final look of the model. Here’s where things get a bit interesting, as I mixed white vinegar and bleach together (This is dangerous when mixed, because it makes chlorine gas), and soaked 00 steel wool in the solution ,and let it sit for two day's.
After the two days, I filtered out the liquid, and let the steel wool air dry, then I crumbled it into a powder, and mixed it with isopropyl alcohol and applied it to the sub. Once everything was dry, I shot it again with Future and sprinkled different colors of Woodland Scenic’s flock onto the model.
For the base I used an old shelf In which I had trimmed with dark colored molding. I used blue construction foam board, trimmed it to the base size, and cut out the center where the sub was going to sit.
I then attached the foam to the wood, let the glue dry, poured in some plaster, and nudged the sub into its new home. I used a Woodland Scenic’s “stone mold” for the rock, tinted it with slate grey dye, then weathered it, and a final sealing with Future.
The next step was adding the fish-nets shown, in which I used veil material (cloth mesh) and cut it to the size. I then threaded a line through certain areas of the net, for a more realistic look.
Then all that was left was to add the sand, (which was from my yard) and a final weathering of the base-work, topped off with a clear coat to seal the deal.
Great diorama! Very original and and the "weathering" of the hull is great. Nice touch with the ROV.
Thanks for sharing
OCT 01, 2007 - 11:05 PM
Very nice, an original idea, and the clever use of the suspended R.O.V. gives an immediate indication that this is submerged, despite the lack of 'water'. You could perhaps add to that by adding one or two (bright) orange buoys to the fishnets, floating upwards.
Looking at the great rust effect, a question comes up (sorry, bad pun.. ) Considering that the Submarine was designed to be submerged a lot, and painted accordingly, would the whole sub rust as quick as this? This is not to question Robert's diorama, just a general thought.
Henk
OCT 01, 2007 - 11:46 PM
Hi Henk
Good question, and the answer is yest it will rust a lot! There is U-1277 sunk near the portuguese northern coast and it is a diving atraction. Several documentaries have showed that the outer casing of the sub has rust a lot, to some points it has even disapeared (bow and CT mostly). The specific built material, temperature of the water and its salinity will make a hull last longer or less... currents and type of bottom (sand, mud, rock or mixed) can also prevent the disapearence. Sandy and muddy bottoms prevent the weathering to some point.
You also have to remember that submarines go to overall refits and repairs after a period at sea (depending of the type, the mission and time frame we are talking about), but never intended to spent everyday under the sea for sixty years
Hope this helps
OCT 02, 2007 - 12:30 AM
Yes take a look at the titanic shes rusted like crazy because shes at a specific deep'd that organizums eat rust. Now look at the bizmark theres hardly any rust on her because shes is deeper than titanic witch means less organiizumtoeat the wood deck and the metal.
And thank you for your comments and input.
OCT 02, 2007 - 03:29 AM
Cool diorama. I think the ROV really adds to the effect, sort of gives it a story line.
The rust looks really good. I'm not going to try mixing vinegar and bleach, but its an interesting method.
As for the comments about the rust. I've only seen pictures of sunken ships and it seem like they all rust different, so there isn't really a right or wrong way to do it.
Great build. I like it.
OCT 06, 2007 - 11:25 AM
Copyright ©2021 by Robert Scott. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-09-29 00:00:00. Unique Reads: 4095
