1⁄700IJN Seaplane Tender, Akitsushima
7
Frank Portela shares with us a fine gallery of images, of the IJN Seaplane Tender, Akitsushima.
"This build is of Pit Road's waterline, 1/700th scale IJN Seaplane Tender Akitsushima. The model comes with both the Emily and the Mavis float planes. This special release (W50) came with a small P.E. fret with replacement parts for the main mast, 35t crane, bridge platform supports, front and rear DF antenna masts and aircraft parts."
"I built her up about 5 years ago mostly out of box, only adding railings. Top notch fit with Pit Roads usual soft light grey plastic. Looking back at the model now, I find myself questioning my choice of paints, the model is too bright, the linoleum an odd coat of orange, and the railings a contrasty light grey".
"The base is a mixture of fine silty sand mixed with white glue and water (about 60-20-20%) this mixture was sculpted to the ships edge and allowed to dry. Once dry, I used oil paints to cover the sand, a mix of blue with a touch of green, yellow and white. Once dried, I hand painted gloss coats to get the reflection off the water."
hello Frank,
the model,base and water looks great to me.thanks for sharing.
JAN 05, 2008 - 01:20 PM
I've got one of these & I'd like to try to do this camouflage scheme. Any ideas as to the paint shades, say in Colourcoats or the equivalent? Thanks.
JAN 06, 2008 - 04:13 AM
Good to see you back Frank
Thanks for sharing your Akitushima - good work, although an "old" model
JAN 06, 2008 - 06:11 AM
very nice! special mention for the little Emily!
I really like the way all the colours match each others -even the red plaque just adds something to the whole,
congratulations for a very appealing model/diorama
JB
JAN 06, 2008 - 06:27 AM
Thank you all for the kind words.
Ken, I'd like to help you out with the colour selection but I'm afraid it's been a while since I painted the ship. To make matters worse, I use a mix of pre-shading and post-shading, which means there's probably about 4 to 5 layers of greys and greens on the hull of the ship. Paints are mainly Tamiya and Polly Scale acrylics followed by water colours for the washes, the details are hand painted with Humbrol enamels.
Frank
JAN 06, 2008 - 02:35 PM
Copyright ©2021 by Frank Portela. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-01-05 00:00:00. Unique Reads: 12053
