MSW Vendor Profile~The Small Shop
2
The Nutter Set - USA
The Nutter - A Revolution in Ultra Detailing
Product Features
Main Tool - CNC Machined HG Aluminum Hard Anodized Finish
*Tri-foil for consistent results - One 6" x 6" sheet
Firm rubber works with the foil for constant accurate shapes
Hex tips 0.5mm 1.0mm and 1.5mm
Rivet tips 0.25mm 0.5mm 0.75mm 1.0mm
Steel probe handle with Black Oxide Finish for weight and durability
Tip Storage unit (holds 7 tips) keeps tips safe & organized
*Tri-foil contains a central lead core. The same precautions should be used as when working with any lead bearing substance, even though very little actual contact with lead is expected due to the protective outer layer on each side.
In addition to photo-etch bending tool, the Small Shop also offers other PE tools that will aid the modeler in success...
Deluxe Brass Assist Rolling Set
‘True’ cylinders, tie downs, hinges, clamps, brackets & grab handles all with one tool.
Product Features
Excellent for shaping radius, U-Shape or cylinder parts.
Includes one each Aluminum rods 3/4", 1/2" & 1/4"
Includes one each Stainless Steel rods 1/8" & 3/16"
4"x4" CNC Machined Rolling Base
High grade aluminum hard anodized in a clear finish.
Machined channels are perfect for your rolling needs!
Soft rolling deck enables ‘true’ cylinders to be rolled
Beams to form tie downs, hinges, tool clamps & brackets
Bending Comb - Matched Grab Handles every time.
Instruction tips for getting the most from all the features
"Standard Rolling Set Also Available"
Large Photo Etch Cut-Off Set
Use for removing larger pieces from the PE frets. Especially useful for Ship builders and Railroad hobbyists
Product Features
Two 8" x 10" black Plexiglas bases
Clear Press with Knob - 1 Large & 1 Small
Especially useful for large Naval and Railroad projects.
Makes removing PE parts from the fret a cinch
Prevents deforming of valuable photo etch.
Blade won't skip or break like when cutting on Glass.
Clear press allows you to see and hold the parts
Black bases provide excellent contrast
Helps keep photo etch organized
Parts don’t fly away into the carpet monster
Use with a hobby knife and #10 blade (not included)
Instructions included.
Minor assembly required
Product Features
Product Features
Product Features
Very nice feature Gunny.
Its nice to see people who used thier own interests to take thier company in a whole new direction.
FEB 16, 2008 - 07:19 PM
I really enjoyed that article. It was well thought out and very informative. I've been to their site and I balked at the price of their products, but after research, and this article I don't know of any comparible products. I'll be placing my order within a few days for one of the benders and I like that PE cutoff.
FEB 16, 2008 - 10:24 PM
Copyright ©2021 by Mark R. Smith. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-02-17 00:00:00. Unique Reads: 28039
