1⁄700HMS Warspite (03)
5
The Project...
The resin Warspite from WEM, 1/700, was another commission I had it is definitely not a kit for a novice. My copy had serious issues and in all honesty I should have return it back but I choose the difficult route of trying to piece it together instead. Once finished however the kit does look good. I had to weather again a bit more than usual partly to hide/distract the eye from the main problems of the kit which are a non flat hull, not straight bulges, superstructure bits that don’t sit on the deck evenly, etc.I guess the moulds are running a bit old now .Would I want one for me? YES! Would I build one again? NO if it is like my copy.
beutiful rendering. You mentioned it was a consignment piece. May I ask how long it took you start to finish?
AUG 08, 2009 - 08:25 AM
Since i was on full time employment at that time i could work on the model only during weekends .So i would say between 6-8 weeks , mostly if only working on weekends.However as you get a bit bored working at the same model all the time i did manage to finish another 2 models that were half started in between that time .In terms of man hours i would estimate to be around 80 possibly more as i had to construct the base/case as well.Since then i have been made redundant (another victim of Gordon's wisdom in England) and i have ALL the time in the world to finish models both for me and my potential clients a lot faster.There is of course the associated burn out so some time off here and there when you built so intensively is a must to keep your sanity.
AUG 08, 2009 - 08:39 PM
Copyright ©2021 by Kostas Katseas. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2009-08-03 00:00:00. Unique Reads: 8867
