1⁄72German Type XXVIIB Seehund Midget Submar
5
"Jan Klarbęk (MrMox) shares a fine gallery of images of his build of ICM Models, 1/72 scale German Type XXVIIB Seehund Midget Submarine, in this "On Display" feature!"
This its ICMs little Seehund kit in 1:72 - you will find a review right here
All in all its enjoyable build, very much straight forward, and you are soon at the painting stage, which is what I find most enjoyable.
I have painted it pretty much like I would have, if it had been one of the bigger subs. First a gentle pre-shading with very dark gray, then a light over spray with a light gray, and then some highlights with a middle-gray on the center of the panels.
After a coat of future, I added decals and sealed them with another coat of future.
With the base-paint under a solid coat of future, the boat was washed with oils and rust was applied with a fine brush. A coat of dull lacquer and a finishing light dry brush completed the paint job.
The base is a solid piece of wood, sanded and lacquered and the "groundwork" is done from cardboard and cork with a layer of plaster - painted and added a replica submarine badge.
A very fine little build and an enjoyable entry into the world of submarines, should you have such ambitions!
Hi Jan
Very good presentation of the Seehund!
I like it a lot - even if it is a filthy sub
Congrats!!
JAN 27, 2010 - 06:46 AM
Thanks Mark and Rui!
- hey - thats whats so cool about subs, not all that spit “n polish routine
Cheers/Jan
JAN 27, 2010 - 08:07 AM
Very nice, Jan, a well executed piece of artwork. The black and white picture really gives it believability.
JAN 28, 2010 - 08:21 PM
Nice job. Good weathering, without being over the top. That must draw a lot of attention at clubs or shows for being so unusual.
JAN 29, 2010 - 06:32 AM
Copyright ©2021 by Jan Klarbęk. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2010-01-27 00:00:00. Unique Reads: 15231
