1⁄721:72 Airfix RAF ASRL to Royal Navy MGB
7
Starting the project entailed removing quite a bit of canvas protection from the cabin & deck as the M.G.B did not have any. The main change was in the rear gun area and the main cabin. The deck area entailed removing the flat sections in the aft gun area and installing the round base and eight depth charge racks.
Four on each side. The cabin gun turrets had to be removed and covered over because the twin Vickers were installed on either side at the forward side of the c cabin area. These had to be scratch built. I am not sure if 1: 72 scale kits of these guns exist.
These turrets were completed thanks to Mr. Connelly getting set of line drawings from John Lambert (www.lambertplans.com). These drawings were very helpful to me in that I had little knowledge of the Mark V mount.
The turrets were constructed from a small test tube, around which I wrapped some canvas. I decided to use canvas because the photos that I had as references seemed to indicate a fabric material was around the turrets. The guns, supports, and sights I made from wire, wood and styrene plastic. I fashioned the gun-sights from photo-etched ones from another model.
Other location changes were necessary for the mast, life rings, ready service lockers, lines, canvas containers and the Carley float was located on the foredeck.
The Carley float life-raft is located on the foredeck. (Stan Pienkowski photo)
The rear mast attachment area was also adjusted for upfront protection of the rear gun. The biggest difference in the looks of the boat are the lack of canvas protection and the Vickers gun turrets which are along side of the main cabin.
The model, nearing completion. (Stan Pienkowski photo)
Details of the depth charges, the 20mm and the depression rails. The mufflers come from a Revell PT-109 kit. (Stan Pienkowski photo)
The color scheme was created by using White Ensign Models’ Colour Coats RNO3, Admiralty Light Grey, and RNO1 Admiralty Dark Grey. The black was model master flat black and the others are as listed by Mr. Connelly. The black base was used to match the bottom of the boat. I am pretty happy with the outcome of this project since I have not built too many British boats.
I considered this project to be what one might call a semi-scratch-built model. That is because of all of the changes made to the basic kit. I want to thank Mr. Connelly for the opportunity to work on this type of project.
In conclusion, I would like to thank, one, my brother for giving me this built-up model as my 2009 Christmas gift and two, I would like to like Stan Pienkowski for building it. This project turned out to be poof-positive of my long-held theory of this result could be achieved with this kit without major work on the hull. I am very pleased with the outcome.
The finished model. The two twin Vickers gun turrets were scratch-built by Stan Pienkowski and the flag in these accompanying photos was replaced by a correct "White Ensign". (Stan Pienkowski photo)
Details of the scratch-built Mark V powered mount for the Vickers 0.5-inch guns. (Stan Pienkowski photo)
Excellent job, and very interesting conviersion.
Great work Stan
NOV 17, 2010 - 09:52 PM
Thank you Guido. I like the outcome. I might ask him to do something with my Revell Vosper. Maybe making it as a Vosper which were used as a G.I.S boat by the Italians into the 60s and into the 70s.
Garth
NOV 19, 2010 - 06:21 AM
Hi Garth,
Nice looking build. The gun tubs look a little to wide compared to the picture but it's a fine looking boat. Good conversion.
NOV 19, 2010 - 09:17 AM
That may be due to the constraints under which the builder had to work - that is, build, without modifying the hull, a 70' boat on a 63' hull. At 1/72 scale, the model is a bit over 1" too short and about 7/16" too narrow. Had one of the 63' MASB/MGB been selected, this would not have been a problem.
The turret placement may also contribute to this perception. If you look at the photo of MGB 61 and others of her sisters, you'll see that the back of the turret is in line with the back of the charthouse.
There's a 2'3" x 5' 0" open cockpit directly behind the charthouse. The original superstructure for this group of boats was nearly identical to this (70' CPB MTB), including the turrets on the trunk cabin. These turrets were later removed, the openings faired over, and the MKV turrets mounted.
These items aside, it's a lovely model and a fine example of the builder's skill.
Al Ross
Al RossNOV 19, 2010 - 04:36 PM
Well,...
I like the model. It looks fine to me ...
And, ... Stan and I went back and forth for several weeks before Stan decided that no modifications would be needed ... and since he is qualified and classified as a Master Builder, I defered to his judgement ...
Plus, since my brother was paying for the build, and more work equals more money ... I didn't ask for more than what was ABSOLUTELY needed ....
Mr. Ross? You always need to rain on my parade - don't you?
Thank you again,Mr. Ross .....
NOV 20, 2010 - 02:05 AM
Copyright ©2021 by T. Garth Connelly. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2010-11-14 00:00:00. Unique Reads: 17074
