1⁄350IJN Yamato
2
IJN Yamato...
I'd like to share some photos of my last project, the IJN Yamato Tamiya 1/350, New Tooling built as full Hull in her final configuration. Aprox 200 hours of work.
+ Tamiya 46cm Metal Barrels Set
+ Tamiya Hand Rails Set
+ Tamiya IJN Navy Boats Set
+ Wooden Deck by Pontos Model
+ Naval Figures by Gold Medal Models
+ Some scratch details for the planes, boats, radars, flagpoles and others
References:
+ Gakken #50 and #54
+ Super Illustration #745 Yamato by Model Art
Excellent build....very nice subtle weathering!
Thanks for sharing.
MAR 09, 2013 - 01:51 PM
Really first class build Jorge!
I am about to start building the new tool Yamato as well, using similar upgrades. Only real difference is that I am using the Tamiya wooden deck.
I do have a couple of questions though and I wondered if you could answer them?
Did you fill in the hull join line between the front and rear sections of the lower hull pieces? Its a very small gap but I wondered if it needed to be filled. I have a couple of reference books but cannot find anything specific to guide me?
And, with the Tamiya hand rails - any hints or tips to get that job done well? You seem to have done an amazing job with the kit. My current plan is build up the hull, put the hand rails on and then paint as an assembled item, putting the wooden deck on last. I will do a similar method for all the superstructure/armaments. Is that what you did?
Finally, with the wooden deck, did you weather that down at all and if so, what did you use?
Hope you can steer me in the right direction
Alan
MAR 04, 2014 - 09:17 PM
Copyright ©2021 by jorge andres rivas krause. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2013-03-10 01:40:17. Unique Reads: 7018
