1⁄350The HMS Illustrious
10
Model Shipwrights is please to present James Jacob’s recent accomplished builds; The HMS Illustrious. James used Airfix’s 1/350 scale kit to complete this piece and shares with us a little of that experience from the construction.
I was lucky enough to receive the 1:350 Airfix HMS Illustrious kit for Christmas 2014 and cannot rate the kit highly enough. I have previously built a couple of other warships in this scale so was looking forward to getting sucked into this kit from the moment I unwrapped it!
The HMS Illustrious R06 is the second of the Invincible Class Light Aircraft Carriers of the British Royal Navy ansd was commissioned in 1982. Sadly now, the ship has been decommissioned due to the Ministry of Defence's budget restructuring which is in favour of the two new Queen Elizabeth Class Aircraft Carriers currently under construction. At 22,000 tonnes and 210 meters in length, the Illustrious was considerably smaller that the US Navy Supercarrier fleet; however, despite its smaller size, the compliment of up to 22 aircraft including the infamous VTOL Harrier Jump Jets proved an effective fighting platform.
The box artwork is very impressive, as is the size of the box itself. The artwork does show the flight deck where a couple of Lynx helicopters are present, along with a compliment of Harrier VTOL fighters. Unfortunately, Airfix did not supply the Lynx helicopters and were not included as part of this kit, but I am certain that aftermarket kits can make up for this.
Moulded in grey styrene, the kit can be built as either full hull or water line versions. One observation I noticed was that the plastic was fairly thick, not only on some of the parts but also the sprues; some being the same thickness as a pencil! After using aftermarket photo etch sets on both my previous builds in this scale, I really wanted to 'go to town' with this build and get hold of the White Ensign Models set, although it was very pricey. A web search and by asking the Google+ modelling community I am part of, resulted in me finding out that WEM sets are no longer in production and it was virtually impossible to get hold of one for my project. Not to be put off, I saw this as an opportunity to do the best I could from the spares box and some creative thinking!
The build itself is pretty straightforward, with the main lower hull being moulded in two halves and a stern plate. These parts enclose a 'core' to which you build up the various sponsons and inset details. You can opt to have the two flight deck elevators (mounted in the middle of the flight deck as opposed to the outside like Nimitz class carriers) either raised or lowered. I felt that if they were lowered, it would be very difficult to see any detail so fixed them in the raised position.
Progress on the hull went painlessly and quick up until I glued down the flight deck and realised that I would need to replace both the cat walk and safety netting if I were to match what I was missing from not having the WEM kit. I had some aluminium mesh left over from a past build which looked close enough to the safety netting so cut some of this to size and affixed it with super glue. The WEM kit would have required cutting out the base of the cat walk piece and replacing these sections entirely, but this was too complicated for me to replicate. I used left over photo etch from my Enterprise build to add safety railings across the hull.
The island however did receive plenty of photo etch and styrene additions. This piece was almost unrecognisable once I had finished with it! Before gluing the island to the flight deck however, I completed the painting, using Tamiya Sky Grey and several gloss coats ready for the decals. The flight deck is literally covered with decals and all in, took about three hours to complete over a number of evenings. This was again coated, this time with matt varnish and left to dry for several days.
I then moved onto the airwing, which comprised of 8 aircraft, 4 helicopters and 4 harriers. They were painted and the recessed panel lines made to stand out by using an Indian ink was which was then dabbed off with cotton buds. Luckily, Airfix does offer this aircraft sprue as a 'kit' you can buy it if you wish to add more aircraft. If you decide to build the Illustrious, I strongly recommend making the purchase. Once the aircraft were all painted and varnished, the hull and island were glued together and I moved onto the fun part - making the seascape.
Last year I made my first waterline seascape using an old Titanic model as a proof of concept to see if I could. This went really well, so I purchased a 6mm thick piece of MDF, had it cut to size and decided to go for it. The hull was first glued to the base using 5 minute epoxy and then I covered the base with a thin layer of interior filler, followed by giving it a fair representation of deep ocean water. After 24 hours, I gloss coated this to give the paint a good surface to stick to.
I then proceeded to paint by hand around the base of the hull using Tamiya Sea Blue, moving outwards about ten centimetres. I then sprayed outwards from there. Next Tamiya's Medium Blue and Flat White were sprayed on to show deep water churned in the right places to show a passing warship. This was then given three coats of Humbrol gloss, followed by a coat of Vallejo Gloss Varnish to give it a realistic shiny water look.
I then glued down the air wing which was to be positioned on the flight deck. At this point I had an epiphany remembering I had an unused set of Eduard carrier figures in the spares box. Being pre-painted, all I needed to do was to cut them from the sprue and stick them to the hull.
Lastly, I mounted four aircraft on thin brass rods and fashioned two helicopter rotors from some clear plastic from the household recycling bin. Spinning rotors were drawn on with a Sharpie prior to two coats of Tamiya Smoke.
With the base, this really adds to the size of the model and is a sizeable entity when placed on the dining room table! I'm really pleased by this and do not feel that the lack of a WEM set has made any tangible difference. When I told her I was done, my three year old daughter said 'Wow Daddy!' so that's good enough praise for me!
If you have any questions or would like to see work in progress shots, please let me know.
Thanks for reading! -James
Model Shipwrights would like to thank James Jacob for providing his own build review of the 1/350 scale HMS Illustrious from Airfix
James,
You have done a fine job on this ship!
Really like all the activity on deck and the animated props
really add a sense of motion.
MAR 15, 2015 - 04:10 AM
Well done James! Great little (big) dio you have there!! Thanks for sharing!
MAR 15, 2015 - 05:17 PM
Thank you Todd! Especially for letting me share the pictures in the first place!
MAR 15, 2015 - 05:20 PM
Great work James!
Its pleasing to see you enjoyed the build so much and good to see a modern vessel featured too
Russ
MAR 17, 2015 - 02:06 PM
Absolutely fantastic build, truly amazing.
Am I right in thinking that you displayed this ship at the Scottish IPMS show at the end of April this year?
JUN 11, 2015 - 08:17 AM
Thanks Klaus-Adler! No, that wasn't me I'm afraid but I am gobsmacked to think that someone would have thought one of my models would be worthy to be displayed at a model show!
JUL 11, 2016 - 01:21 AM
Copyright ©2021 by James Jacob. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2015-03-15 15:03:04. Unique Reads: 5959
