Part VI – Summaries
(A) Modifications summary
As previously mentioned, the codes next to the modifications also appear on the comparative set of drawings. The letter indicates the period when the modification occurred, whereas the number bears no particular significance.
Before October 1939
A1 Spray deflector added.
A2 Breakwaters added outboard of the 88mm deck gun.
A3 Two emergency rescue buoys moved inside deck hatches.
A4 Black patch over diesel exhaust outlets painted over.
Pre-war features removed on the 19th August 1939
B1 White “47” on tower painted over.
B2 Small oval plates near bow removed.
B3 Bronze eagle plaque at front of tower removed.
B4 White “U-Flottille Weneger” and “U 47” inscriptions on the two red horseshoe-shaped lifebelts painted over.
B5 Identification markings on the two red and white emergency rescue buoys removed.
Late October/Early November 1939
C1 Spray deflector extended around tower.
C2 Small railings fitted to top side of spray deflector.
C3 Small railings fitted over each of the snorting bulls.
December 1939 - February 1940
D1 20mm Flak gun re-sited to aft end of tower.
D2 Cartridge tray on starboard side of 20mm mount removed.
D3 Tower enlarged to accommodate 20mm gun.
D4 Grill added in place of some ventilation holes on the starboard side.
D5 Leak in interior fuel bunker II repaired.
D6 Short circuits in GHG hydrophones repaired.
D7 Only one jumping wire attachment point fitted on each side of tower rather than two.
D8 Very small fairlead added to both trailing edges of tower bulwarks.
D9 Rear navigation light altered.
8th/9th March 1940
E1 New 20mm MG C/30 anti-aircraft gun fitted.
E2 Modifications made to radio sets.
April/May 1940 F1 Starboard diesel repaired.
F2 Crack in starboard diving tank IV repaired.
F3 Both diesel exhaust outlets modified from round to oval (perhaps during this refit or previous one).
Before July 1940
G1 Pillkoppen pennant seen in photos for the first time.
G2 Altered commander’s flagstaff without attachment to tie down commissioning pennant.
July/August 1940
H1 Air trunking fitted.
H2 Tower rungs added on top of air trunks.
H3 Short ladders fitted between air trunks and deck.
H4 Additional three bars, in a triangular shape, added to the forward deck railings.
H5 Two wires added per side from the forward deck railings to the aft deck railings.
H6 Wooden seats removed from aft deck railings.
Late October 1940, September/October 1940, and December 1940 to February 1941
General overhauls, with no external changes visible in photographs.
(B) Main colours summary
Pre-war
Upper colour medium blue-grey Dunkelgrau 51 (RAL7000)
Lower colour dark grey Schiffsbodenfarbe III Grau (RAL7016)
19th August 1939
Pre-war markings and inscriptions removed in afternoon
8th October 1939
Temporary Chamberlain drawing
15th/16th October 1939
Original bull insignia added, both facing to left
Early November 1939
Both bulls repainted facing forward
6th July 1940
“66587 to.”, with leaves below, present near bulls. First appearance in photographs of Pillkoppen pennant.
Sept/Oct 1940
Upper colour changed from Dunkelgrau 51 to a darker grey, possibly Schlickgrau 58.This change may have occurred during the July/August 1940 refit. The upper colour remained in this shade of grey thereafter.
