I don't see why it would not work for a 1/350 ship. There were times when I have seen the ocean table flat while we were out cruising around. Then of course there were times when it was a rocking and a rolling.
Dade, do you leave the tape on hull permanently?
Quoted TextDade, do you leave the tape on hull permanently?
Hey Kenny, yes, I leave it on permanently. After I apply the tape and make sure it's buffed on nice and flat, I run some liquid glue over it and the surrounding plastic to help lock it in. The process works very well and really adds to the look of the hull, as long as the real thing had noticeable lines (most IJN ships did). Here's my 1/700 Nachi with the same process, after primer.![]()
Try it out sometime.![]()
Guido, the tape lines are used to simulate weld lines (scroll up a little to see my primed Nachi with tape weld lines). Yes, this effect is a little over scale, but since many things in 1/700 are a little too big, I don't mind this. It's a kind of reverse scale effect. Many IJN ships had very noticeable lines, so I like to add these lines as a nice visual referance to help enhance the "IJN-ness" of the ships. Of course, ships that looked smooth in real life (like my escorts), I wouldn't do this to, but ships like the Nachi and Hiryu had very noticeable lines so I do this to make the ship more "solid" to the viewer's eye...
