Nice work on the boat, it sure looks used, but still within the reasonable.
I cant see your last picture for some reason I only get a red X.
Cheers/Jan
U-2536 (Revell's Type XXI in 1/144)
MrMox
KitMaker: 3,377 posts
Model Shipwrights: 985 posts
Posted: Monday, August 17, 2009 - 07:08 AM UTC
conus00
KitMaker: 70 posts
Model Shipwrights: 69 posts
Posted: Monday, August 17, 2009 - 09:50 AM UTC
Thanks, Jan.
Exactly what I wanted to accomplish. I wanted the boat to look more weathered than usual. I figured that towards the very end of the war German resources were stretched very thin and I don't think that they put too much effort into maintenance of the school boats.
Also, by 'can't see last picture' do you mean the brass plate mockup?
MrMox
Posted: Monday, August 17, 2009 - 07:27 PM UTC
Thats correct - allso a little nit-pick you might be able to use for your next build. Below the waterline rust tends to "bloom" instead of "run" - so unless the boats on land or in drydock the rust below the surface would not run.
Cheers/Jan
conus00
KitMaker: 70 posts
Posted: Monday, August 17, 2009 - 08:03 PM UTC
Can you see it now?
Also, good point about the rusting. The boat is still missing last clearcoat so I might try to fix that a little bit.
I will try something different on my next build. Thanks.
MrMox
Posted: Monday, August 17, 2009 - 10:49 PM UTC
I prefer the bottom one, much better balance without the Adler.
Cheers/Jan
Cheers/Jan
