So it came to this realisation:
The basis for my idea:
First steps:
The MiniArt vacuparts
assembled to this part of quay wall
Basis for the display was a picture frame (bought from a supermarket at a price of 3.99 €) with dimensions 20x42cm.
To create the water a piece of seafoil (HO-railway accessory by Faller) was used; the method to use silicone was too complicated form e to show such a little piece of harbor water. The Verlinden Seehund took place in the water and the Bronco Seehund will find his place jacked up on the quay:
The backwall to beart he quay was built by plates of styrofoam (also Faller).
The undercoat of this parts is "Chaos black" (spray can Games Workshop)
Single bricks were painted by a brush; the following Tamiya colors were used: XF-9 Hull Red, XF-50 Field Blue and XF-63 German Grey – looks strange, but after drybrushing with XF-53 Neutral Grey and XF-54 Dark Sea Grey this was the result:
The water edge with XF-2 White and XF-65 Field Grey was spoted dry.
A curious drawing on the water was a later droped attempt to simulate a bit of the underwater parts of a Seehund.
The next step was wood. Some beech rods were cut to build the poles, but at first they were grated with a needle and later painted grey:
The gap between the wall and the water was filled with water thinned casein glue – on this pic not yet dried, but when dry it will appear transparent.
Some rust arround the iron rings (Tamiya pigment) and of course some gulls sh... shouldn’t be missed:
I think it’s satisfying up to, but now to the boats:
They were built OOB, only with some small adds: limiters fort he rudders and grap handles near the hatch:
The assembly went on without any problems, filling wasn’t neccessary.
Both Seehunde are of different variants and built by different wharfs. Only some openings on the „roof“ were aligned with the originals.
The boats were airbrushed: XF-24 Dark Grey after blackening the flood holes;nachdem die Flutschlitze geschwärzt wurden; the Bronco Seehund got a white conning tower due to the Ijmuiden pics:
Aging by thinned paint /XF-9 Hull Red) and some drybrushing:
The scapermarks and the tracks of walking were made with a silver pencil
This is it till now – only some little adds to the boats – and thnn: the figures!
It wasn’t easy to find a soldier with a dufflecoat to show Gen. Foulkes, but I found him!
To be continued...
Finally some pics of the mockup:
