The second installment of his series on the famed four stacker destroyers from both World Wars, crew-mate Karl Zingheim (Captsonghouse) shares another fantastic Naval History diorama in this MSW feature!
Link to Item
Enjoy!
FEATURE
Hell Off Lunga PointGunny
Posted: Thursday, November 04, 2010 - 11:18 PM UTC
MrMox
KitMaker: 3,377 posts
Model Shipwrights: 985 posts
Posted: Thursday, November 04, 2010 - 11:29 PM UTC
Impressive, a interesting story told with some of the most difficoult effects to work with in modelling - well done!
Cheers/Jan
Cheers/Jan
DieselDog
KitMaker: 67 posts
Model Shipwrights: 69 posts
Posted: Friday, November 05, 2010 - 10:33 PM UTC
Cool!
Maybe you've explained before, but how'd you do the explosions?
Tailor
KitMaker: 1,168 posts
Model Shipwrights: 676 posts
Posted: Saturday, November 06, 2010 - 02:18 AM UTC
As usual I am stunned by the gripping action of Karl's diorama. You can clearly identify a Zingheim when you see one.
Amazing work, Karl!
Guido
Amazing work, Karl!
Guido
Posted: Saturday, November 06, 2010 - 03:15 AM UTC
Hi Karl
Interesting story, excellent model and an all action effect.
Excellent stuff, very impressive.
CaptSonghouse
KitMaker: 1,274 posts
Posted: Saturday, November 06, 2010 - 05:53 AM UTC
Cool!
Maybe you've explained before, but how'd you do the explosions?![]()
Hi Chuck!
I should submit a How-To feature, but in the meantime here's a quick primer:
1. You must have an internal light source. For simplicity and economy, I use
white Christmas tree light strings. In the case of the McFarland scene, I
opted for a light rig that had clear spherical bulbs about a half-inch (12mm)
in diameter. My HMS Repulse dio, however used the standard mini
Christmas white light set.
2. The incandescent gas bubble of the blast itself can be kitchen wax paper or
white kitchen parchment (freezer paper) because they're translucent. I
crumple a sheet tightly and then smooth it out again and crumple once more
and smooth out to both put in many irregular creases and to induce a convex
shaped so it can be gathered into a hollow ball.
3. Using florescent paints, a mix of oranges and reds with the odd bright yellow
highlight. I coat the outer side of the paper ball. Be careful with the paint
brand as I've found some flake off in bits from the paper, giving your
scene a bright orange case of dandruff!
4. Make a hole in your dio base and even in your model (!), if the scene calls
for it, large enough to pass the light bulb socket and secure it with the power
cord leading out the bottom. Install the light bulb if it could not fit through
the socket hole.
5. Take up the painted paper and gather it up into a hollow ball, cutting away
excess paper as it forms a rough sphere. Refer to photos of actual fireballs
to determine the relative size of the sphere. Since the orange fireballs are
more impressive than yellow ones, that means I'm depicting explosions that
have started to cool a second or so after the initial detonation, so it may be
necessary to add flying debris (and small splashes) around the blast.
6. Envelope the light installation with the cupped paper, ensuring the paper
and the bulb are not touching--we want a simulated fire, not a real one!!!
I've found that plastic zip ties are ideal for securing the throat of the paper
sphere around the light socket base.
7. Next, I use black polyfibre cotton (you can paint it black, too) and spread it
thinly about most of the surface area of the sphere. This adds a vaporlike
texture to the fireball and helps hide the hard edges of the folded up paper.
Don't put the polyfibre on too thickly, you are adding texture, not a layer.
8. Finally, turn on the light and add or remove polyfibre until you can hear the
explosion in your mind. The blasts look great in person, but for
photography, I've found the camera lens over-emphasizes the reflected
studio light on the cotton's fibres, making them appear like brillo pads. To
compensate, I use the basic retouch feature to fuzz out and blend the
extreme reflections.
There you are, so go out and light some fires!
--Karl
rea00cy
KitMaker: 47 posts
Model Shipwrights: 44 posts
Posted: Saturday, November 06, 2010 - 10:22 PM UTC
Very impressive diorama, Karl! The smoke and fire effects look very convincing so this diorama gives a gripping and dramatic impression of the the story you are telling us. I love your work and I would really be delighted to see the real thing.
As Guido pointed out, your signature is clearly visible in this kind of action diorama that as a modeler one don't have the chance to see and enjoy frequently.
As I've incursioned in this field of "special effects" trying to recreate fire and smoke in my naval dioramas I know very well how difficult is to make fire and smoke and produce a realistic and convincing impression.
I agree with you that the use of an internal source of light is a must as I did years ago on my USS Indianapolis http://www.modelshipgallery.com/gallery/ca/ca-35/700-jm2/jm-index.html) The use of fluorsecent paints and black polyfibre cotton are a novelty for me and I would like to give them a try. Could you provide me with some links to these products?
Looks like both of us are tunning the same frequency...
Happy modeling,
Augusto
Happy modeling,
Augusto
CaptSonghouse
Posted: Sunday, November 07, 2010 - 08:33 AM UTC
Hey Augusto!
Insanity loves company.
As for product sources, I use paints that can be found on the hardware shelves as much as at the LHS'. Just look for the brightest oranges and reds you can find. Avoid so-called 'florescent' yellows--they turnout to be more yellow-green.
The material I use for smoke was produced years back as a Halloween novelty and is no longer available. However, ordinary polyfibre takes paint well and you can paint your own. I also understand there is a black quilting stuffer made for darker fabrics produced in Britain, though I have not used it yet.
Good luck and happy detonating!
--Karl
--Karl
Posted: Monday, November 08, 2010 - 04:51 AM UTC
Hi Karl
Your dios always look like stills taken from an old movie!
I really like the action you portray (like the gasoline drum flying over!), the courage to make difficult effects and I must say that I would like to see some shots taken with less light - much like Guido took with is "Perfect Storm" dio
I think you managed to make and excellent job with the old Revell model... You have a tendency to attack the "dogs" and make them jewels (not the best alchemy trick, but you understand what I mean).
Congratulations on another great scene!
CaptSonghouse
Posted: Tuesday, November 09, 2010 - 07:27 AM UTC
I wanted wanted to thank everyone for the kind comments on my latest submission.
Guido, your third-person reference was much appreciated, though it makes me sound like a Matisse (or least a Klimt)
! Rui, for my part, the only doggie thing about the Revell 4-stacker is the almost non-existent flare on the bows--that's one of those cure-is-worse-than-the-problem matters. But, everything else is fixable if you have the insanity to replace 90% of a kit...
I've produced night scenes before, but not for photography. Finding digital cameras with slow shutter speeds to absorb all the light will be a challenge. Any assistance on low-light digital photography from the Kitmakers would be appreciated.
--Karl
I've produced night scenes before, but not for photography. Finding digital cameras with slow shutter speeds to absorb all the light will be a challenge. Any assistance on low-light digital photography from the Kitmakers would be appreciated.Thanks!
--Karl
