Acrylics will work just fine followed by some drybrushing to
pick up on the highlights ie white caps, etc.
Keep the washes on the thin side as to blend with what you
have already painted and not to overwhelm the base coat.
And thank you for the compliment on the Sunderland, I would
of liked to do some weathering, but the client specified a
clean look on the aircraft.
1/144 Revell Soviet Trawler Volga
Posted: Monday, May 19, 2014 - 07:18 AM UTC
vivkulan
KitMaker: 143 posts
Model Shipwrights: 17 posts
Posted: Monday, May 19, 2014 - 01:35 PM UTC
Posted: Monday, May 19, 2014 - 03:49 PM UTC
Looking better but I would still darken with darker blue/gray, if you are representing Nordic waters.
vivkulan
KitMaker: 143 posts
Posted: Monday, May 19, 2014 - 11:51 PM UTC
Will do. Thanks.. Any suggestions on how I can simulate water wet effect on the deck and sides of the ship? Will future be enought to create it or should I go for products like MIG or AK interactive rain effect?
Posted: Tuesday, May 20, 2014 - 02:55 AM UTC
I would actually recommend Acrylic Glossy Medium.
This is a thick white paste which will dry totally clear.
Being a thick paste, it will not only create a wet look if
extended by brush, but applied in layers and a little thicker, will give the water some depth.
It will be good to overcoat your water with this, again
it will help create the illusion of depth, to some extent.
Biggles2
KitMaker: 7,600 posts
Model Shipwrights: 833 posts
Posted: Tuesday, May 20, 2014 - 03:11 AM UTC
IMHO, artist's gloss acrylic gel (heavy) is the best and cheapest way to go. Available at artist's supply shop, inexpensive, odorless, and in a jar, which will last several ship dio's. Brush it on top of your basic water (celluclay, or whatever) with a wide brush (1/2" - 1 "), the gel is thick enough to form wave tops. It goes on opaque white, but dries transparent and smooth and glossy ( although I've discovered that Humbrol (clear) Gloss Enamel will give a really wet look to the water). The gel, since it's acrylic, can also be colored or tinted with any acrylic or water based paint.
Biggles2
Posted: Tuesday, May 20, 2014 - 03:13 AM UTC
Damn! Joe said the same thing while I was typing mine!
vivkulan
KitMaker: 143 posts
Posted: Tuesday, May 20, 2014 - 03:36 AM UTC
Joe and Biggles,
I was asking about making the deck and the hull wet. Can acrylic gel be used for the same?
Posted: Tuesday, May 20, 2014 - 06:16 AM UTC
Yes.
Apply thinly to the deck and upper hull sides where there is
run off.
Apply thick to water line area where ship meets water to
create splash effect.
Apply a genereous layer on finished water, after painting, to
create an illusion of depth.
run off.
Biggles2
Posted: Tuesday, May 20, 2014 - 06:31 AM UTC
Joe and Biggles,
I should put my glasses on and learn to read! There is a method of using absorbent cotton stretched out and soaked in the same acrylic gel to make the bow wave, as well as deck run-off. I haven't tried it, but there is a tutorial on here somewhere.
vivkulan
KitMaker: 143 posts
Posted: Wednesday, June 11, 2014 - 01:33 AM UTC
Posted: Wednesday, June 11, 2014 - 01:54 AM UTC
Yes! That water looks much better!
Really nice dio.
Really nice dio.
Posted: Friday, June 13, 2014 - 03:22 PM UTC
Vivek,
Thank you for posting this. I had a lot of fun with my Trawler Volga and you have built and painted it so well!
Posted: Friday, June 13, 2014 - 03:30 PM UTC
Grauwolf & Murdo,
Thank you for the instructions on making water and for modifying this kit! Vivek isn't the only one to benefit - I'm really glad I found this thread!
Posted: Friday, June 13, 2014 - 05:47 PM UTC
Frederick,
Thanks,
C[ ]
Thanks,
C[ ]
vivkulan
KitMaker: 143 posts
Posted: Tuesday, June 17, 2014 - 07:57 AM UTC
Vivek,
Thank you for posting this. I had a lot of fun with my Trawler Volga and you have built and painted it so well!![]()
You are welcome Fred. Please do post pics of your Volga.
