Thank you a lot for all the nice comments about my Ukuru. It keeps my Spirit high and encourage me for further Projects within this genre
@Jean: Your ship is also a Beauty, I especially like your rigging very much! May I ask you which figures you did used?
@Frederic: Yes ist PitRoad together with the Eduard set for this ship and some small goodies - you can see everything at the beginning of my blog.
Gentlemen I was able to make some more progress: I painted around 20 tiny sailors from two diffeerend Fujimi IJN sailors sets. I was not sure about how to paint them until I found a book again I already owned since some years about Japanese uniforms during WWII. There are some drawings about sailors and officers in a late war, khaki colored uniform. As I also did see this kind of uniforms in real war footage and in some japanese war movies also it must be the correct way to paint them:
and this is how they look already placed at the ship. Although 20 sailors it doesn´t look crowded so maybe I will add some more later:
Parallel to figure painting I also started to create the sea Diorama. I created the displacement waves (correct word?) with bluetac first and added an Aluminium foil as basic layer. Then I added normal wall color and improved some spots with acrylic gel. After everything was completely dry I did primed it with valleyo RAL 7021 primer and sprayed some different cloudy layers in dark gray and blue at the Surface. After this I did drypaint the top Surface with a light gray and put an gloss varnish on top for sealing everything for the next steps. It did looked this way:
After drying time I ripped thin cleenex towels apart and soaked them in watered white glue, colored a tad in light gray (just a bit). It should simulate the waves the boat is generating during ist movement. After finishing the Operation Cleenex it looked like this:
After this was dry I painted different dots and layers of thinned vallejo paints (different grey and blue color tones). This is how it looks now at my workbench:
Next step is to seal everything again with one thick spray of gloss varnish when it is completely dry. Then I can start to place the ship at its place and begin to blend in the acrylic gel.
Thanks for watching!
Thomas
