HMS Warspite 1/350 with Pontos
ChurchSTSV
Arizona, United States
KitMaker: 350 posts
Model Shipwrights: 175 posts
Posted: Tuesday, November 14, 2017 - 11:53 PM UTC
Following!! I love the PE step by steps!! Great job!
TRM5150
Staff MemberEditor-in-Chief
MODEL SHIPWRIGHTS
Posted: Wednesday, November 15, 2017 - 06:04 AM UTC
Great seeing this back on....looking great Si!
KitMaker: 6,919 posts
Model Shipwrights: 6,490 posts
Posted: Friday, November 17, 2017 - 01:17 AM UTC
True that mate-those disruptive patterns can be a real challenge!
Especially when you have to mask across etch
Will get there, bit more done, will post latter today / tmrw
Posted: Friday, November 17, 2017 - 01:18 AM UTC
Thanks Charlie,
Glad you are enjoying the build.
Posted: Friday, November 17, 2017 - 01:19 AM UTC
Good to be back on this one Todd, the momentum is picking up.
Posted: Friday, November 17, 2017 - 03:28 AM UTC
Bit of progress.
Etched detail on the rear of the bridge structure.
and on the underside of the boat deck.
All the superstructure units test fitted,
d6mst0
#453
KitMaker: 1,746 posts
Model Shipwrights: 1,130 posts
Posted: Friday, November 17, 2017 - 06:24 AM UTC
Nice work with the PE. Really like the look of the paint work on the hull.
Staff MemberAssociate Editor
MODEL SHIPWRIGHTS
KitMaker: 2,330 posts
Model Shipwrights: 1,700 posts
Posted: Friday, November 17, 2017 - 06:26 AM UTC
Me too! I really like the look of Warspite all dressed up in her camou!
Posted: Friday, November 17, 2017 - 02:52 PM UTC
Thanks Mark,
for quite a simple two colour scheme it does manage to look striking.
The Pontos etch is very friendly (although the instructions for this very early set are a little on the basic side - later ones are much better)
Posted: Friday, November 17, 2017 - 02:53 PM UTC
Thanks Tim,
Next job, get the upper bridge and the funnel done, then out with windy stick.
RussellE
KitMaker: 3,710 posts
Model Shipwrights: 2,663 posts
Posted: Sunday, November 19, 2017 - 03:30 PM UTC
Looking good Si.
You're braver than I tackling the disruptive pattern on the hull before the superstructure
Posted: Monday, November 20, 2017 - 02:27 AM UTC
Looking good Si.
Braver may be the wrong word Russ,
I have now got the superstructure base coated, (update on the way) we shall see.
Posted: Tuesday, November 21, 2017 - 02:16 AM UTC
Finally, This weekend's progress.
The moulded on wind deflector removed from the flag bridge.
The etched replacement assembled and awaiting bending and fitting.
In place.
Detail added to the 20mm tubs on B gundeck.
Basic assembly on the compass platform.
One little bit I overlooked, until a noticed some funny shaped bits on one of the sprues.
The Vents on B Barbette
The superstructure units sprayed and fitted.
The colour difference is just my bad lighting.
More soon
d6mst0
#453
Posted: Tuesday, November 21, 2017 - 07:02 PM UTC
Those vents on the barbettes are awesome. A lot better then the flat PE versions.
Posted: Wednesday, November 22, 2017 - 12:06 AM UTC
Thanks Mark,
They are rather nice, it is an oft overlooked feature on some kits.
RussellE
Posted: Thursday, November 23, 2017 - 03:41 PM UTC
Back to business as usual! Good to see Si!
Posted: Friday, November 24, 2017 - 12:11 AM UTC
Good to back in the shipyard, should be some more progress this weekend.
Posted: Monday, November 27, 2017 - 02:23 AM UTC
Some progress made.
Basic paint job on the 6" secondary battery,
Washes applied and fitted in place.
Propellers painted and fitted.
Now that's everything below the upper deck in place (except the anchors, on the fo'c's'le.
Capstans and bits in place.
paint on the details, anchor cables and capstan control wheels.
The etched breakwater assembled.
Not yet sprayed, too cold on Sunday, even having well warmed a can, not good results on a test piece.
In which case, a bit of hairy stick work to get the camo under way.
B gundeck has also been painted dark grey.
More soon.
d6mst0
#453
Posted: Tuesday, November 28, 2017 - 05:03 AM UTC
Very nice work. Those props look amazing thin, are they after market?
Posted: Wednesday, November 29, 2017 - 12:35 AM UTC
Hi Mark,
The are, in fact, the kit props, they are very nice in shape; painted with citadel's "Retributor Armour Gold". Citadel's metallic base coats are my go to, for props and other metal bits, brush on like a dream.
kpnuts
United Kingdom
KitMaker: 1,135 posts
Model Shipwrights: 427 posts
Posted: Friday, December 01, 2017 - 11:10 PM UTC
It's a great kit and your doing a great job with it.
Posted: Saturday, December 02, 2017 - 12:59 AM UTC
Thanks Ken,
It is a joy to build, however the pontos instructions are little challenging, this was their first release, and they have improved a lot since then. Cheers
kpnuts
United Kingdom
Posted: Saturday, December 02, 2017 - 01:58 AM UTC
When I did mine I used the dx pack I don't think those instructions were great either tbh I hate pe (I know it makes a big difference but I still hate it) you're doing great though.
Posted: Monday, December 04, 2017 - 01:00 AM UTC
Thanks Ken,
I do enjoy working with PE, although at times it does frustrate me, that could be because I try to run before I can walk.
You are right though, particularly when you get to 1/350 or above it does make such a difference.
Posted: Monday, December 04, 2017 - 02:18 AM UTC
The progress for this weekend was mostly with the paintbrush.
Camo on the bridge structure.
The hanger and the after superstructure.
The holes for the ladders provided by pontos were a bit narrow, so a lttle file work was need. The left side is done (looking down on the picture) but not the right.
The ladder in place, the pontos ladder fold very well, but they are fragile, fortunately will be hidden behind the after twin 4"
Camo needs tidying up too.
The stacks of liferafts that sit on next to the above ladders.
More soon.
