Modeling in General: Advice on...
Need some general advice? Place it here.
Using Scale Drawings
gunnerPhil
Virginia, United States
KitMaker: 30 posts
Model Shipwrights: 6 posts
Posted: Tuesday, April 14, 2020 - 11:18 AM UTC
Hello,
I am slowly accumulating things for a project and have a question about scale drawings. I am going to attempt build a Japanese CV in 1/350 scale. most of my drawings are 1/400 or 1/200 scale. How do I shrink or enlarge them to 1/350 scale ?? Thanks in advance.
Dioramartin
New South Wales, Australia
KitMaker: 1,340 posts
Model Shipwrights: 0 posts
Posted: Tuesday, April 14, 2020 - 02:14 PM UTC
Hi Phil, someone ought to check my math but using a good photocopier (if any Copy-shops are still open) you could enlarge/reduce as follows;
Reduce the 1/200 drawings by 57.14% and Enlarge the 1/400 drawings by 112.5%
If you can稚 change the plan sizes anywhere I guess you値l just have to use those conversion figures for each part you make! Mind-bending & if I知 wrong it only goes to show I知 no engineer, but at least I tried!
AussieReg
Staff MemberAssociate Editor
AUTOMODELER
#007
KitMaker: 7,677 posts
Model Shipwrights: 151 posts
Posted: Tuesday, April 14, 2020 - 02:53 PM UTC
Tim, your numbers are spot on but the wording should be reduce to and enlarge to (rather than by).
Pedantic, I know, but the results are very different!
Cheers, D
Dioramartin
Posted: Tuesday, April 14, 2020 - 03:22 PM UTC
Thanks Damo! I知 quite shocked actually, so now I知 good to do a scale model of the Tacoma Narrows bridge right?! Yep you're right I began to think I should have said 鍍o after I posted but I was too exhausted to log back in until I壇 had a nap
AussieReg
AUTOMODELER
#007
Posted: Tuesday, April 14, 2020 - 03:43 PM UTC
Fair call Tim, you can't rush these things and naps are important. I should have realised that's where you were and left it a bit longer before I commented
gunnerPhil
KitMaker: 30 posts
Posted: Wednesday, April 15, 2020 - 05:18 AM UTC
Thanks for the help...have a nap and a beer on me
MrchntMarine
KitMaker: 55 posts
Posted: Saturday, May 02, 2020 - 09:33 AM UTC
if this helps....
https://drive.google.com/file/d/1ZWbd5zPMO1U5A4cpeLnBvvpjePw7A50P/view?usp=sharing
Removed by original poster on 05/02/20 - 22:05:55 (GMT).
gunnerPhil
KitMaker: 30 posts
Posted: Sunday, May 03, 2020 - 11:06 AM UTC
Hey,
Thanks a lot I had this along time ago in a magazine article and it disappeared over time and my many moves. I is now saved on my computer.
jon_a_its
KitMaker: 1,309 posts
Model Shipwrights: 11 posts
Posted: Sunday, May 03, 2020 - 09:42 PM UTC
My favourite tool is Frank Krenshaws Scale Calc
Easy to use, you can go from known to known scales (1:96 to 1:35, etc) or from known length on drawing, to desired output length, Metric, Imperial or mixed! it will give you the %age enlargement needed.
The above takes the whaa??? out of it for those of us mathematecally challenged.
