1/200 Nichimo Hatsuzuki build
Posted: Sunday, August 23, 2020 - 04:03 PM UTC
Nice rew0rk, Tim!
Posted: Sunday, August 23, 2020 - 11:14 PM UTC
Cleaned up and test fitted with the vertical frames in place, the assembly captures the look of the Hatsuzuki’s windows much more successfully than my first attempt!
Absolutely!
Posted: Monday, August 24, 2020 - 02:53 AM UTC
Nice rew0rk, Tim!
Ditto.
Kevlar06
Washington, United States
KitMaker: 3,670 posts
Model Shipwrights: 173 posts
Posted: Monday, August 24, 2020 - 03:12 AM UTC
Tim,
I knew you’d overcome the window issue. Spectacularly I might add— now onward and forward!
VR, Russ
VR, Russ
Posted: Tuesday, August 25, 2020 - 09:06 AM UTC
Great job on the bridge windows Tim,
They look the business.
rdt1953
KitMaker: 1,098 posts
Model Shipwrights: 34 posts
Posted: Tuesday, August 25, 2020 - 01:04 PM UTC
Well done Tim - really looks better - keep it coming !
Posted: Wednesday, August 26, 2020 - 01:59 AM UTC
Thanks guys!
The bridge structure is mostly done for now - I just have to go back and do some minor touch ups (the fender racks have gone missing) and then it is on to the next step.
Ripster
Wien, Austria
KitMaker: 970 posts
Model Shipwrights: 446 posts
KitMaker: 970 posts
Posted: Wednesday, August 26, 2020 - 02:09 AM UTC
Beautiful work!
Posted: Thursday, August 27, 2020 - 01:01 AM UTC
Thanks Graham - almost done with the bridge!
The pilothouse vertical window frames are attached only to the lower bridge to allow the roof to be removed for later installation of the interior parts and for painting.
This is how things look at the moment with the roof removed.
Just for fun, I added a basic support structure to the pilothouse overhead from Evergreen .010”X.030” strip.
It won’t be easy to see, but the structure is in there for anyone who cares to look!
Posted: Thursday, August 27, 2020 - 02:57 AM UTC
Tim,
Nice finish on the bridge. Of course I thought you would at least add a coffee bar for the crew...LOL.
Posted: Thursday, August 27, 2020 - 04:25 AM UTC
Tim,
Funny you would mention that... in Gakken Reikishi-Gunzo's Pacific War Series Volume 23 IJN Akizuki-class Destroyers, their 1/100 scale model seems to show a little table with a teapot on it:
–maybe the IJN version of a coffee bar?
Posted: Thursday, August 27, 2020 - 04:58 AM UTC
Really like the structure on the bridge deckhead, even painted I think it will stand out more than you think Tim.
great job,
great job,
Kevlar06
Posted: Thursday, August 27, 2020 - 06:52 AM UTC
Tim,
Again, fabulous work on all the little details. Just out of curiosity, how are you going to do the window treatment? Or do we have to “wait and see?”
VR, Russ
VR, Russ
Black_sheep
Bayern, Germany
KitMaker: 823 posts
Model Shipwrights: 551 posts
KitMaker: 823 posts
Posted: Thursday, August 27, 2020 - 07:06 AM UTC
Stunning work Tim, simply stunning!
rdt1953
Posted: Thursday, August 27, 2020 - 02:39 PM UTC
In the words of Oliver Twist - Please sir - more !
Posted: Friday, August 28, 2020 - 02:56 AM UTC
Thanks guys!
All that handling and reshaping while fitting the window frames caused some collateral damage, but after re-applying the little round roof vent hatches and replacing the damaged radar room supports and fender racks, the bridge is good to go.
Posted: Saturday, August 29, 2020 - 10:00 AM UTC
Tim,
VR, Russ
Hi Russ,
I guess it is a “wait and see” – because I don’t really know myself! My first thought was to fit individual “glass” panes from acetate, but this may not happen as I now hesitate to add anything that might obscure all that detail added inside the pilothouse. It is hard to see inside there as it is. Plus, windows without glass would be authentic as Japanese navy ships had window sashes that slid down into the lower frames for better visibility/ventilation. You can just see this on the bridge of Yukikaze with one front window completely open and another halfway down:
Then again, most observers would expect to see glass panes there... so I dunno.
Kevlar06
Posted: Saturday, August 29, 2020 - 02:35 PM UTC
Tim,
I think something like Microscale Crystal Clear would work, but will obscure the detail. How about very thin clear acetate, bent to curve around the inside of the frames, maybe even with some gaps for open windows? I once saw a large model of the USS San Francisco, and the builder used microscope slip cover glass (which is very thin) to replicate the bridge windows. I asked him how he cut such material, and his reply was “very carefully”! Later he told me he etched the glass slip covers on a flat surface with a razor saw, and “ snapped“ the glass at the etch, but also said he went through about 100 slip covers to get 30 good windows. Just a thought!
VR, Russ
VR, Russ
Posted: Sunday, August 30, 2020 - 12:14 AM UTC
Thanks for the ideas Russ. Not quite there yet, but I'll give it some thought as I prep the other areas.
Weapons next!
Weapons next!
rdt1953
Posted: Sunday, August 30, 2020 - 06:21 AM UTC
Hi Tim - once again my compliments.
For my 2 cents I think the bridge needs glazing at this large scale .
Russ’ idea on slide covers seems worth looking into.
Acetate seem like it would be fine also - you could leave a sash open here and there for viewing.
What’s next - weapons?
Cheers - RT
Cheers - RT
Posted: Sunday, August 30, 2020 - 07:55 AM UTC
Cheers - RT
Thanks Richard, I suppose you are right; no glass in the windows at this scale would probably seem odd. I’ll likely use bits of acetate when the time comes. As for the weapons, yes, they are next – except I first need to adjust the funnel footrails.
I had liked the look of the brass footrails the on the funnel, but since I changed the style of the bridge footrails, the funnel rails really should be changed as well to match.
Posted: Monday, August 31, 2020 - 12:57 AM UTC
Really, those look amazing.
bwiber
KitMaker: 436 posts
Model Shipwrights: 31 posts
KitMaker: 436 posts
Posted: Tuesday, September 01, 2020 - 09:42 AM UTC
Something you might consider for the windows is UV cured resin. You could make it as thick, or thin, as you want, and with a bit of work you can make a mold that will make it just the size you want.
Just a thought.....
Just a thought.....
Posted: Tuesday, September 01, 2020 - 12:02 PM UTC
Just a thought.....
Thanks bob, that's an interesting idea... but I'll probably just go low-tech with acetate
Posted: Friday, September 04, 2020 - 03:05 PM UTC
Mark C
Thanks Mark. I too thought the brass footrails were attractive, but they definitely clashed with the different style plastic footrails applied to the bridge.
I wasn’t all that happy about doing these rails all over again, but the finer plastic footrail supports would clearly be more accurate, as this picture of IJN Oboro shows... so I bit the bullet and pulled out the wires, removed the 21 brass support fittings, and filled in all the holes.
Another look at my references also showed the need to add additional supports with closer spacing as well as another row along the funnel cap. To make the changes I drilled out 50 new holes (using scrap 1/400 railing for spacing) and cemented .010” plastic rods into them as had been done on the bridge structure.
I again used my handy homemade tool (a bit of .015” sheet with a .018” hole punched in it) to help trim the supports to a uniform .015” length.
As on the bridge structure, the footrails were attached to the supports with Tamiya Extra Thin cement.
I’m definitely not fond of rework, but the footrails are now more accurate – and the bridge and funnel structure details match!
