1⁄1200
Thursday, February 13, 2020 - 02:26 AM UTC
Revell has released a 1/1200 IJN battleship Musashi.
Most recently released by Revell Germany, this small scale battlewagon was originally produced the Italian company Casadio as one of their pre-assembled "Miniships" waaaaaay back in the early 1970s. Over the years it has been reissued many times as an unassembled kit by Revell UK and Almark in England, Revell/West Germany, ESCI in Italy, Sablon in France, and by both Model Power and MPC in the United States. The same plastic has also been marketed as the Yamato. The only differences among the various releases have been in the instructions and box art.
This toy/model from the early 1970s is a very simplified, snap-together affair designed for quick building. When I built it as a kid back then I was among those for whom the kit was apparently designed – wargamers and young modelers. At the time I liked the snap together design, but the poor fit of the parts was annoying. And the model is very basic: while the one piece hull is recognizably a Yamato-class, the shape is vague and toylike. The complex main guns and funnel are reduced to single parts, and the prominent mainmast is missing entirely. The bow profile is not accurate (although it is fixable with a little shim and sanding). The decks look nice with a delicate wood plank pattern and other details. The first superstructure deck should not be planked, but again – not perfect, but fixable. Aircraft are only generalized single float monoplane representations, in any case wrong; if they are meant to be Aichi E13A "Jakes", they should have twin floats, if Mitsubishi F1M "Petes" they should be biplanes. The 127mm type 89 guns are only vaguely correct, and the numerous 25mm triples are molded directly to the decks and turrets. Finally, there is a problem with the configuration of the antiaircraft guns. The model is reasonably accurate for the ship’s final appearance at the Battle of Leyte Gulf, but there are too many 25mms on the main deck, and the lower level of six 127mm mounts were never installed on Musashi (she had 25mm triples in those positions).
Still, the kit has its good points. The bridge windows are neatly represented as recessed squares, and two alternate main turrets are provided so you can depict the sister Yamato after she got the extra antiaircraft guns on the turret tops. Perhaps the best aspects of the kit are its affordability and simplicity; at less than ten bucks and a mere 33 snap-together parts, you can have a finished battlewagon cheaply and quickly. And although basic, the completed model does resemble the great ship; with a scratchbuilt mast and a few other minor improvements, the kit can be built into a presentable little Musashi.
This model is certainly no masterpiece of the kit maker's art, but when it appeared in the early 1970s it was superior to comparable Pyro and Lindberg offerings, and it is still far less expensive than the various pre-assembled wargaming and collector models out there. Taken for what it is, this little Musashi isn’t a bad kit at all.
The 1/1200 IJN Musashi is listed by Hobbylink Japan at https://www.hlj.com/1-1200-scale-ijn-battleship-musashi-rev06822 and can be ordered now for about US$10.
THIS STORY HAS BEEN READ 1,882 TIMES.
Revell Reviews | MORE |
Chris Craft Cabin Crusier by Frederick Boucher | of 1 ratings, 100% found this helpful | |
USS Oriskany CVA 34 by Frederick Boucher | of 2 ratings, 100% found this helpful |
