Saturday, June 28, 2008 - 09:21 AM UTC
Gator's Paint Masks is proud to announce the release of their new Gator's Grip Precision Tip Hobby Glue Applicator. This applicator allows you to put just the right amount of glue where you need it. And, because you are using less glue, the drying time has been shortened. Inside, you get a 3cc syringe, a 22ga blunt applicator tip and a 14ga tapered refill tip. Retail cost is $2.00.
  • applicator
To use the applicator, place the tan tapered tip on the syringe and fill with the desired amount of glue. Remove the tip and place it in a small cup of water to keep it from drying out. Attach the precision tip to the syringe and begin applying glue. When finished, flush both tips and the syringe with water. Make sure all the glue is flushed out of the applicator before putting it away for next time.
$2 ? You're craaaazy! Hope you're making some money on this great little item. Looks very useful! Thanks, Gator!
JUN 28, 2008 - 08:44 PM
Don't worry, I am.
JUN 29, 2008 - 08:02 AM
Ahoy Kenny These look like a great product. Just a small question are they reusable? I assume so they can just be cleaned out after use with some sort of solvent. I guess I will need to buy oops "invest" in some glue plus one of these huh. Cheers Sean
JUN 29, 2008 - 10:14 AM
Hi Sean, It's completely 100% re-usable. Just flush it with water. Kenny
JUN 29, 2008 - 12:01 PM
My order is in. That is the perfect tool to use with your Gator Glue. Precise application in amount and location. Perfect! Cheers, Mike
JUN 29, 2008 - 06:21 PM
I thought you supposed to sniff it not inject it! OK, I'm up for tihs one, I'm always willing to try something new. Best wishes with your new products. Peter F
JUN 29, 2008 - 08:26 PM
Well, sometimes you gotta do what you gotta do to get the kit built.
JUN 30, 2008 - 05:38 AM
You guys just now figuring out to use syringes to apply glue. Man I've been doing that with liquid glue for 20 years now.
JUN 30, 2008 - 08:31 AM
But we're not as old as you Steve.
JUN 30, 2008 - 09:51 AM
THIS STORY HAS BEEN READ 5,534 TIMES.
ADVERTISEMENT
Gator's Paint Masks ReviewsMORE
Precision Applicator First Look
by Mark R. Smith | of 4 ratings, 100% found this helpful
Gator's Grip Hobby Glue First Look
by Mark R. Smith | of 18 ratings, 100% found this helpful
ADVERTISEMENT
