Making Weld Beads, an MSW SBS
STEP 3: Enhance the Weld Bead
Soften the strip styrene with liquid cement.
Using the tool, press the sharp rounded tip into the strip styrene on an angle so you get a curved indent.
Move the tool tip back VERY SLIGHTLY on the strip styrene, and press in again.
Repeat along the length of the strip styrene.
Apply liquid cement to the bead to soften the edges slightly (and keep it in place.)
Copyright ©2021 by Glenn Cauley. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-12-23 00:00:00. Unique Reads: 11242
