Making Weld Beads, an MSW SBS
Evolution of the Technique
The tool & technique I discovered is similar to that used by armour modellers to create weld beads. They use an Xacto blade with a broken tip to score plastic; but I don't know if they use a plastic strip as the foundation for the bead.
I feel that using my tool is safer to use than a broken Xacto blade... no sharp edges to have to worry about other than the tip.
AND... using my tool & technique gives more realistic weld beads, since it imparts the proper semi-circular arc to the bead and allows the bead to dome up. Using the tip of a broken blade gives flat scores and does not make the plastic dome up.
Copyright ©2021 by Glenn Cauley. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-12-23 00:00:00. Unique Reads: 11242
