1⁄35Program 5 Command and Communications Boat
6
"New MSW crew-mate Rick Bellanger (RickBellanger) shares his fantastic build of Masterpiece Models 1/35 scale Program 5 Command and Communications Boat in this "On Display" Feature!"
COMMAND AND CONTROL BOAT (CCB)
Displacement: 80 tons
Length: 60.5 feet
Beam: 17.5 feet
Draft: 3.5 feet
Propulsion: 2 Gray Marine 64HN9 225 hp, 2 shafts
Speed: 8 kts
Crew: 11
Weapons: Mk I Mod 0 MON: 1 40mm L/60 Bofors, 1 .50 AN/M-2HB mg (co-axial), 3 20mm Mk 16 or 2 20mm Mk 16 and 1 40mm Mk 19 grenade launcher, 2 Mk 21 7.62mm mg, 1 81mm Mk 2 Mod 0 mortar.
Note: CCB was the tactical communications center for a River Assault Division. The structure aft of the 40mm turret is the communications center.
Some Further Reading and Exploration
Brown Water Enterprises
Rivervet.com
MRFA.org
the vessel...
Length: 60.5 feet
Beam: 17.5 feet
Draft: 3.5 feet
Speed: 8 kts
Crew: 11
The Model....
Kit-1/35th scale, full resin kit. "Program 5 Command and Communication Boat", from Masterpiece Models. Eventually, I plan to incorporate the model with several other vessels moored along side a barge.
Rivervet.com
MRFA.org
Beautiful!
My father in law was a PCF crewman, he talked about these, the monitors and zippos...
GREAT WORK!
OCT 23, 2008 - 11:26 AM
Interesting subject, and beautifully done, very real. Can't wait to see the whole shebang and river!
OCT 25, 2008 - 01:12 PM
Hi Rick!
What a way of making your entrance into MSW! Welcome to the crew!
Your project is surely one of those that I look forward to see any progresses and of course, the final result.
The Program 5 CCB is very good
Congratulations
OCT 26, 2008 - 03:18 AM
Welcome aboard Rick,
Thanks for sharing your model with us. Spotless workmanship throughout your build. I look forward to the completed barge diorama.
Frank
OCT 26, 2008 - 06:53 AM
Copyright ©2021 by Rick Bellanger. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-10-23 00:00:00. Unique Reads: 4765
