1⁄700Building Hasegawa's IJN Nachi
24
The included photo etch was very robust and contained plenty of goodies including catapults, DF finder, funnel caps and railings. Unfortunately, no ladders or stairs. The PE is very good... surprisingly so. The metal is a nice thickness, firm, but easy to work with. Everything is sized very well, with the exception of some PE gantries (see below). The railings are the kind I most prefer (and also the rarest type): stanchions with feet. What this means is that instead of railings with one long gutter, or with only stanchions- these are mostly only stanchions, but with small feet every few stanchions or so that must be bent up at a 90 degree angle, thereby providing a larger place to glue and giving added strength and stability to the entire rail (and looking more accurate than the gutter type).
Overall it's a good kit, but it has some annoying fit issues. This kit is really summed up with lots of dry fitting. The problem spots are:
--Above waterline hull to the bottom is not a tight fit- will require some putty.
--The forward funnel base is a little too big where it goes under the superstructure and will need work.
--The upper levels of the superstructure have some gaps that will need to be filled.
--The hole in the structure for the rear center leg of the aft tripod to go into is not big enough. It will have to be opened up more.
--There is a PE platform gantry that goes directly in front of the aft funnel and is surrounded by a walkway on both sides. A small walkway piece goes between to the gantry sides. It will have to be filed down or the gantries will be too far apart. Even then, the fit inside of the outer walkways is too tight, so the inner walkway walls will have to be filed down some to fit around the gantries. This spot will require a lot of experimenting.
--There is a forward platform on PE gantries also. Care must be taken to modify these gantries to fit as well.
Howdy Grant, thanks!
For the rigging, I'm gonna be lazy and quote my Mikasa article (although I should put this in each of my builds from now on)...
I use fly fishing tippet which is a type of resin coated thread that will hold its shape and is very strong (lures are made out of this stuff). Now comes the voodoo. For my support rigging (funnels and masts) I use 6/0, which is .005 mm. For standard rigging, I use 8/0 which is .003 mm. Did you catch that? The higher number tippet corresponds to the SMALLER diameter. The stuff I use is called UNI-Thread. It's available in many colors (I have black, brown, and tan) and sizes and comes in 200 yards, which is more than enough.
To expand on this, I unravel a large amount of tippet from the spool so I won't have any issues with the spool colliding with the kit. I put a small spot of CA glue where the rigging will start (use a toothpick). After the CA has dried, I start to run the rigging to where it next needs to go (say, the top of a mast), put a dot of glue there to secure it, and so on. The nice thing about tippet is that thanks to the thin resin coat, it can be "shaped". So if your rigging has to hang loose and bow along a curve, just run your finger along to shape it before anchoring to the second point.
For items like the small insulators seen near the rigging connections, that's just a small dab of white glue that will congeal into a blob naturally and works pretty well. Then paint it when dry.
I hope this helps!
FEB 06, 2009 - 04:59 AM
Dade
Yes - that helps alot. Seems easy enough. Thanks for the assistance!
Grant
FEB 06, 2009 - 05:15 AM
Hi Dade!
Excellent build article, even if you said that you keep it simpler, it will be a good reference for my own Nachi (same model)
I really appreciated the tip of using the tape - have to try it one of these days, and perhaps not on my Nachi.
Congratulations on another great model in your collection
PS: Sorry for the long overdue comment
FEB 06, 2009 - 06:14 AM
Hi Rui, thank you very much for the very kind words! And please don't think your comments were overdue. I am very happy to receive encouraging words no matter what the time frame.
FEB 06, 2009 - 06:42 PM
Another beautiful build.... great pics and blog. again, thanks for taking the time to document and taking so many high quality pictures. I picked up that kit, was on sale last month half-price from Squadron,(dont tell my wife I broke my New Year's resolution of no more kits!). Will use your blog as my "instructions assistant". Cheers
FEB 07, 2009 - 12:12 PM
Thanks guys and glad I can help! James, at the time I got mine, it was 40% off, but to see it later at 50% off...
FEB 07, 2009 - 06:51 PM
Great looking ship! I like the hull plate tape trick, very cool.
FEB 16, 2009 - 06:40 AM
Great build, Dade, that ship must stand in a proud place in your living room.
FEB 16, 2009 - 07:59 PM
Copyright ©2021 by Dade W. Bell. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2009-02-04 00:00:00. Unique Reads: 19593
