Creating Water From Foil
5
Step 7…
Mask the parts of your base that you don't want painted with tape. Spray primer on the foil (the following image depicts the base turned around to better catch the light for the photo of the waves).Step 8…
The primer has revealed some small tears in the foil.These tears can be fixed easily with some small dabs of putty. Because water is chaotic, the putty doesn't have to be smoothed as it will blend in with the water when done. If the putty isn't the same color as the primer (as Tamiya putty is with Tamiya primer), make sure to spray a small shot of primer onto the putty.
Step 9…
It's now time to put on the base color. This doesn't have to be perfect and usually can be sprayed from a can, as long as the paint dries smooth. This base color is Testors Model Master Blue Angel Blue spray.Comments
Looks a heck of a lot easier, safer, and cheaper than resin. I may have to try that with the pibber build I'm doing. Thanks for the heads up Jim!!
FEB 22, 2009 - 05:24 AM
Nice technique and nicely presented. I think I might just ahve to give this a try! (after about a bazallion models on the ways already)
FEB 27, 2009 - 11:59 AM
If anyone knows, does the foil keep its shape better after all the paint, glue, and clearcoats are applied or will you just have to be very gentle with the display from that point onward?
DEC 18, 2011 - 09:34 AM
What a great idea Jim,
As Ed said,looks a lot easier than the resin and everything else I've tried.
Thanks
Tom
DEC 19, 2011 - 11:07 AM
Copyright ©2021 by Dade W. Bell . _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2009-02-10 00:00:00. Unique Reads: 26740
