1⁄700Building the Garibaldi
2
The Build:
I began by prepping the hull with light (300 grit) sanding and minor flashing removal. I then set to work painting and detailing the under deck at the stern.This ship has a large open deck underneath the flight deck which was cast on the hull, but had a second piece of the flight deck which went over it. So after painting the under deck, I tackled the seam issue on the flight deck. There are no details on the flight deck. It is perfectly smooth and flat. (Save the pre-molded multi-positioned second elevator ) This is both good and bad for the modeler. Details tend to get sanded off, but details can be used to hide a seam line.
Hi David
Thank you for sharing your experience with this kit! It turned out very good and it is really a shame that the model doesn't include a dedicated PE set.
You managed to make a very interesting finished product
Congratulations
OCT 06, 2010 - 09:22 AM
Copyright ©2021 by David J. Salvin. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2010-10-06 00:00:00. Unique Reads: 9076
