1⁄700Building the Garibaldi
2
First off is to attach the back end of the flight deck over the main hull. Careful sanding helped get a close seam line between the pieces. Next, I sanded the deck with a sanding block to make sure that the deck didn’t get sanded unequally and become wavy.
Once sanded as close as possible, I used painter’s tape on either side of the seam to contain the next step. I took watered down Elmers’ Indoor/Outdoor wood putty (water based) and smeared it over the entire area between the tape. After a few minutes, I removed the tape (before it dries) Left with a clean putty seam on either side, I let the putty dry overnight.
The next day I sanded it all down with a sanding block. This brought the seam down to just barely noticeable in the right light (but unable to be felt). A few coats of Tamiya surface primer equalized the area and all but removed any trace of the seam.
Hi David
Thank you for sharing your experience with this kit! It turned out very good and it is really a shame that the model doesn't include a dedicated PE set.
You managed to make a very interesting finished product
Congratulations
OCT 06, 2010 - 09:22 AM
Copyright ©2021 by David J. Salvin. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2010-10-06 00:00:00. Unique Reads: 9076
