1⁄35Working with Resin Ships
![]() The turrets ![]() Almost completed |
I begin the ship by painting the hull color. In this case I used gunship gray
with a little black. The entire hull and deck area is painted as well as any
other large parts. Once this has dried a coat of acrylic floor wax (Future or
Kleer) is applied overall to act as a barrier between 2 different colors of
paint and to smooth the surfaces to allow paint to flow more freely. Once this
has dried I brush paint the decks. The paint is thinned to allow it to flow
along the bulkheads and other deck details. The ship is then assembled following
the instructions. Different deck levels are attached to a piece of cardboard and
painted, then glossed. Any windows or portholes are then painted dark blue and a
light drybrush of lightened Gunship Gray is applied. Small parts like
searchlights and guns are painted while still on their sprues then cut off and
attached as required. The photo etched parts are painted the hull color while
attached to their frame then cut out, shaped (if required) and superglued in
place. Once the glue has dried they are touched up with the correct color with a
small brush. The cage masts were painted light gray overall, then referencing
the instructions, were masked off and the lower color was applied before they
were removed and rolled to shape. To shape the masts I began rolling them with a
large diameter paint brush. Then I worked my way down to smaller diameter brush
handles until I had a nice round cross section and the 2 ends met along their
length. Carefully holding it in my hand and aligning the meeting surfaces I
applied superglue along the joint with a toothpick. I used a round file to
enlarge the opening in the center of the mainmast searchlight platform until it
slid easily into its position on the mast. Before I glued it into place I added
the railing surrounding the platform and the searchlights. Once the Fighting top
was attached I cemented the masts into place with slow drying super glue. This
allowed me time to make sure they were aligned along the centerline from above ,
were sitting straight up and down, and were aligned to each other when looked at
from the bow or stern. The blast bags for the main turrets were made by building
up layers of white glue, then painted white. The photo etched boat cranes and
stern catapult crane were bent to shape and assembled. The stern catapult was
replaced with a photo etched catapult from Gold Medal Models Cruiser/Destroyer
set. It may not be 100% accurate for this ship but it looks fine and I preferred
it over the white metal kit offering. Now we are ready to set the ship on the
base.
