1⁄35Working with Resin Ships
![]() Corsair Armadas USS Vestal repair ship |
![]() Almost completed |
By this time the acrylic water has dried and left us with a nice clear gloss
surface over our painted water color. Using a sharp exact you need to cut
through this water, tracing the masking tape outline of the ships hull. Once
this is done you can raise the bow or stern point and peel it off leaving a
space for the hull recessed to the deepness of the acrylic water layer (about
3mm). Now place the built up hull in place using a thin layer of white glue or
the acrylic lacquer to secure it. Once this has dried I like to drill down
through the hull to screw it to the base for added strength. I drill a hole
through the center of the #1 turret mount and the #4 turret mount. Small screws
are used and care is taken that the turrets sit flush on their barbettes.
