1⁄35USS Duluth - A Cleveland Classic
After the fore and aft superstructures were assembled the detail parts were
added. Guns , gun directors, searchlights and the like. All painted to match the
surrounding camouflage pattern. At this time the for a and aft superstructures
are glued in position on the hull, and any touching up of the brass is done.
While all this work is going on I've made bow and wake waves for my base out of
Celluclay. These were then painted blue, then drybrushed white. When dry a coat
of acrylic artist medium was applied overall to give the water some depth. 2 or
3 of these coats would be applied then the masking tape hull outlines cut out
with an x-acto and removed leaving a depression for the hulls to sit in. The
bottom of the hull is coated with the acrylic medium and set into place, all
further work will take place with the ship already mounted to it's base.
The long runs of railing around the main deck level are attached now. I cut out
a full length of railing and dip the first inch or so into the superglue, then
set it into place on the deck's edge. Then using the toothpick I pick up some
superglue and place it ¼ inch or so down the deck and set the railing in place.
Repeat this process until the entire rail is attached to the deck. The more
imposing looking pieces like the radars and catapults are really no more
difficult than any of the railings. Care needs to be taken when shaping these
parts because you need to be careful of the bends you've already made. Curiously
the round SK-2 radar was not on the photo etched parts sheet. It is given as an
option in the plastic pieces and I believe the Duluth had this type of radar
fitted. Not having one available I fitted the square SK radar but will probably
replace it at a later date. The masts were replaced with brass rod and the
rigging was done. The Kingfisher floatplanes were then painted insignia decals
from another Sky Wave set were added as none were supplied in this kit and a
photo etched propeller was attached. Placing the floatplanes in their photo
etched cradles on the catapults completed the Duluth. It was then given a coat
of Testors Dullcoat laquer.
