Goldenpony's Forgotten Sisters Build
Zimbabwe
Posted: Sunday, January 06, 2008 - 03:01 AM UTC
KitMaker: 8,985 posts
Posted: Sunday, January 06, 2008 - 03:50 AM UTC
way back when I was planning to do a Tuscaloosa from the 350 scale San Francisco kit. But as Trumpeter decided to hold it back until February or so, I may not be able to play. Hopefully when the kit is released they will have fixed some of the errors that were found and pointed out with their pre-production showing. I could do the Yukikaze kit. It is a member of the Kagero class DD's. HOwever, it is the most famous of the bunch being how in an 18 ship class, it was the only one that didn't get sunk
VMI "76
Order of the Red Nose Plug
Zimbabwe
Posted: Monday, January 07, 2008 - 12:43 AM UTC
Michigan, United States
KitMaker: 960 posts
Model Shipwrights: 901 posts
Posted: Monday, January 07, 2008 - 01:37 AM UTC
Jim,
Great looking ship you have there. Nice to here that your not have any problems with the build. What scale did you say that was....1/700? Can't wait to see more of her. When you do get to the smaller details, the only advice I can give is to drink less coffee....all that shaking can give you some weird paint lines.
It is not a sin to fall.......It is a sin not too get up......
Posted: Monday, January 07, 2008 - 01:39 AM UTC
Looking good so far Jim.
Zimbabwe
Posted: Monday, January 07, 2008 - 04:11 AM UTC
Jim,
Yes, 1/700. I've never built one that small and never a resin one of that scale. I ordered teh paints and railings today, but found out the railings are out of stock.
Oh well, guess somebody else will have them. I also found a picture fo the ship with somethign special, her "Blue Nose". So, I plan to add that little extra as well.
Lisboa, Portugal
KitMaker: 5,182 posts
Posted: Monday, January 07, 2008 - 10:37 AM UTC
Hi Jim
For the waterline flash and other parts similar flash I suggest the following procedure:
Wet a sheet of sander paper 1000 grit, place it on a wet flat base (kitchen marble bench is a great surface) and make eight figures with the parts, gently and checking it after 2 or 3 eight runs...This way you will get the flash off and keep a even surface, and also you don't breathe any of the dangerous resin dust
It is looking good indeed, and dont forget to paint it in sub-assemblies (much easier and you'll be able to paint all those hidden places) - hope this helps
Keep up
#021
KitMaker: 2,458 posts
Posted: Monday, January 07, 2008 - 11:11 AM UTC
hello Jim,
looking good.
KitMaker: 1,698 posts
Posted: Tuesday, January 08, 2008 - 01:57 PM UTC
looks good so far, so small.... never done resin here, cant give any useful advice!
what railings do you need? I have some unopened:
Tom's Modelworks Modern 4 & 5 bar Rails 1:700 # 758
you are welcome to them if you wish, I dont have plans to use them in the next few months
Cheers! Jim
Zimbabwe
Posted: Wednesday, January 09, 2008 - 12:26 AM UTC
Jim,
Thanks for the offer. I ended up getting a set of those later in the day Monday. I had to get a few other things so I added those ot my list.
Zimbabwe
Posted: Monday, January 14, 2008 - 01:58 AM UTC
Well, nothing new to show today. I will how ever pass this along. I spent most of the week looking everywhere to find the paints for this kit. The two main colors are White Ensign colors, WEM M09 and M10. Nearly every place I looked was out of stock on those two colors. I could have ordered then from England, but the cost was crazy. In the end I did end up finding a suitable substitute for both colors.
I also had to order a set of generic railings for this ship. The PE fret did not include railings. Since I was looking for some other items I was able to grab those fairly easily. I am hoping to get some pieces added in the next few days so I can post some pictures of my progress.
Posted: Monday, January 14, 2008 - 06:29 AM UTC
Did you try GreatModels? I ordered some stuff from them not that long ago, including some WEM paints... Jim
Zimbabwe
Posted: Monday, January 14, 2008 - 06:59 AM UTC
I did try them, but they had every other color instock, except for the ones I needed.
They are a very good place to get those odd ball items.
Zimbabwe
Posted: Tuesday, January 15, 2008 - 12:52 AM UTC
Lisboa, Portugal
Posted: Tuesday, January 15, 2008 - 02:25 AM UTC
Looking good, Jim
A couple of advice (again):
I guess that you have washed the parts with dish washer cleaner. You should prime the parts with Tamiya Grey Primer.
Also it's time to start painting small parts and details, as well as the deck. Than you can mask it with Tamiya Tape or any other masking tape and paint the lighter shade of grey.
Zimbabwe
Posted: Tuesday, January 15, 2008 - 07:52 AM UTC
Skipper,
I used Dawn dish soap for cleaning.
I noticed when I put the 20mm cannon on last night the vents behind them are now hidden. So, I do plan to do some prelim painting this weekend.
My wife has some liquid Latex she uses for her pottery. I wonder if that would work on resin for a mask as well? I know on pottery after you put it down you can trim it with a sharp knife.
I also need to prime the PE before I get ready to use that.
Posted: Tuesday, January 15, 2008 - 10:44 PM UTC
hmmm, very interesting idea, Jim...I would be curious to see if it would work, seems like it should, as it is a liquid mask product...personally, I've never had much luck with these, and stick with Tamiya mask as Skip does...I guess you could test it out on the bottom side of the ship where it would go un-noticed if something were to go wrong....
Don't forget to give your PE a bath in acetic acid (white vinegar) first, my friend...it will give the brass a little surface etching to improve adhesion before priming...thanks for the update, Jim. I'm watching this build closely, as I have both this kit and her other Admiralty variant in my stash waiting to be laid down!
Keep Modeling,
Lisboa, Portugal
Posted: Wednesday, January 16, 2008 - 08:17 AM UTC
Yes you can use it!
It's the same principle as Humbrol Maskol... I usually mask and for bigger areas (in the middle of the mask tape) I use Maskol... It prevents the "coloured fumes" to enter any gap between the tape and ruin the previously painted area.
You're in the good path
Zimbabwe
Posted: Wednesday, January 16, 2008 - 08:26 AM UTC
Good to heal the latex will work. I can thin it down and paint some nice crisp lines with that.
We also use wax to prevent glaze from sticking to areas we don't want to it go. But that is a little harder to remove. Inside the kiln at 2350F(1288C) it sort of melts off.
I will try some liquid latex and see how that works.
Posted: Wednesday, January 16, 2008 - 02:03 PM UTC
Looking very nice Jim.
Zimbabwe
Posted: Saturday, January 19, 2008 - 03:05 PM UTC
Posted: Sunday, January 20, 2008 - 01:22 AM UTC
Ahoy, Jim,
Glad to see that you took the "jump" into the water base, mate!
Gator's technique is easy, and
quite effective, for sure (as well as fun!)...progress looking good, my friend, thanks for the update!
Lisboa, Portugal
Posted: Sunday, January 20, 2008 - 04:09 AM UTC
Hi Jim
The overall effect is very good, BUT please check the wave direction - they should be more or less in the same direction
Zimbabwe
Posted: Sunday, January 20, 2008 - 08:30 AM UTC
Skipper,
Your right about that. I knew they looked off a little. This will be a practice base. I can play with color and see waht looks the best.
I am guess this will peal off fairly easliy, so I can do a better one when it is time to finish my ship.
Also started to add some Haze Grey to teh ship and small parts. I almost started to paint the deck, but noticed, I am all out of thinner.
I'll get more progress later on this week.
Zimbabwe
Posted: Sunday, February 03, 2008 - 02:24 PM UTC
Sorry no pictures with this update.
I did get some time to paintthe decks ofthe D182. The WEM paints are very nice and smooth flowing. I had good smooth coverage and didnothave to thin the paint anytouse it. I also made another base. This one is much better than the first one.
I am waiting to get my PE folding tool so I can start on the masts.
So far I say I am ahead of where I thought Iwould be. I will try to get some photos up by the end of the week.
