I think the hull is more or less ready for paint, unless if any of You can point out something I ought to do - I´m all ears.
At this point I would like to make a small status on the build, allso compared to the review I did
here, which was a inbox review with the shortcommings of such a review - would I still rate it a 85 % - propably not!
I have done a number of alterations, some has been done in a effort to highten the detail level, like the innerhull and the new Nautilus deck, others have been done to get a more true representation of the German type II A.
The extra work is a mix of my own ambitions and the shortcommings of the Special Navy kit and is generally based on, that the kit is a fair CV909 Vesikko but a poor Type IIA
It has along the way become more and more clear to Me, how much the kit is based on the Vesikko and it will be fair to say, that you can build a good representation of the Vesikko strait from the box, but doing a good II A requires a extra effort. It is within avarage modellingskill but care is needed.
A out of the box build is allso possible for most modellers, but there are some design errors on the way, that requires some work. First of all the misplaced axelmount for the aft diveplanes which have to be repositioned, and second the missing locator tabs and holes on the hull which requires a lot of care to get a strait an true fit.
I have so far done a lot of work on the hull in a attemt to upgrade the kit to a German Type II A, I aim for the 1941 configuration of the U6, but I have undoubtly missed a lot in the process…
Floodholes: sealed off the ones speciffic to the Vesikko and drilled out those that where opened all the way and have drilled all the missing round holes in the casing and opened up the long floodhole under the uppercasing.
Keel: Added the cut-out and the 4 bottomvents
Stern: Added the audiosensors and other stuff, added attachments for the wirecutter, these were left on after the cutter itself was removed
Aft: repositioned the diveplanes, added holes for the antennawire and the mounts for the wire to lift it off the hull.
Deck: lifted the deck slightly and added the small steps front and aft - cut the deck straight in both ends instead of pointed. Opened the rear accesshatch and scratced a new hatch - still to do minor detailing like handles and hinges on the various hatches.
Overall: added weldseams .
Innerhull: Scratched a innerhull with various details.
And here a bunch of pictures showing the present state.
