You may be able to see the black base showing through on this one (port bow) where the super glue is showing through. I must not have sprayed the dark color over the Teal Pearl color to prevent this.
Here is a little 1/700 dio that came to me one evening and I worked on through the early morning hours. I just had to do it and get it out of my system
I painted a black siloette of the sub's hull hunder the water. You can barely see that here.
This is the USS James Monroe SSBN-622. I did four patrols in the North Atlantic on here out of Holy Loch, Scotland in the late 1980's.
I call the diorama "BROACH!!" Broaching was usually a bad thing for "Boomers" while trying to maintain periscope depth. The slapping of the planes on the surface of the water made us very detectible to aircraft, surface ships, and the sound made us detectible to other submarines, which is what we didn't want.
Thanks for your comments, guys! This is my first attempt, so I haven't chosen my "standard method" yet (albeit that I'm rather pleased with this attempt)!
I've used "easy to work with" Acrylic paints and rather big, round brushes. This evening, I've cooled down the effects a little (it is easy to go overboard!) and added more white to the wake. Now it is time to wet the hole thing down with some glossy coats.
Cheers! // PolarBear!![]()
Kenny,
I'll check out the Lowe's stuff. What department will I find it in?
