Ahoy Shipmates,
I have been having way too much fun on my Sunday off from work.
Delving into the Tama kit inbetween a midday break to do some shopping has gotten quite a bit done as well as remind me of some of the little oddities that working in 1/700 scale has to offer one. Aside from overly thick out of scale items when they do put things like the supports in areas under things like tubs for gun mounts and search lights, they sometimes miss the boat when it comes to additional parts to make this variation and that one out of one basic kit.
As to the supports for tubs, Lions Roar has a dandy little set of what they call Triangular Perforate Boards in several sizes that fixes that little problem. Of course, you do have to remove the bits that you want to replace. A chisel bladed Xacto Knife comes in right handy for such chores. It all started with the lower levels of the forward bridge and deck house.
You can see I have removed the ones from both of the front tubs as well as one of the side ones in the above photo. As I worked it all out deciding which sizes to use and then one thing led to another and pretty soon, the whole deck house was done.
I used some of Kennys' most excellent Gator Glue to attach the little parts, it gives you a little "fiddle" time as well as is easily removeable if you goof it up and have to redo your efforts, not that I would ever do that, yeah right!
The next thing that came to mind to tinker on was the deck extension that held the catapult tower and the aft three main gun mounts. They make this as a separate part for various iterations of this basic Kuma Class ship kit and as such, the parts that they give you can suffer from various maladies such as fit issues and a lack of certain details. Looking at the upper surface of the part, it jumped out at me that the lines for the linoleum hold down strips had not been molded in place, it was all smooth as the proverbial babies' behind without so much as a dimple. Once I had the two side panels glued in place to the upper part I laid it in place and marked out the locations for the lines that I would have to make up with some of my favorite modeling material, stretched sprue.
Another issue that cropped up when I laid the three part assembly in place on the deck was a fit issue. The whole piece was too short leaving a step from one deck section to the next. Cutting and gluing strips of .015 styrene strip in place to the underside brought it up and a little pass or two over a sanding stick once the pieces had hardened up made it fit as it should. You also get a view of my altered after torpedo mounts in their little hidey hole.
I also added another section of the perforate board to the end of one side and will continue on with some more to bring the detailing up to par with the rest as I go along. I painted the color of the linoleum on the after deck since once I glue that deck section in place it will be nearly impossible to do it easily without slopping some up on the sides of the bulkheads in such close quarters. After adding the rest of my details to the undersides of the deck edges and a few hatches and doors here and there on the bulkheads, I will also paint these areas up using the same Kure Arsenal Gray Model Master Acryl. It will give me a nice break in the lines of color to limit any repainting. I will also be adding some supports that the kit does not provide but does show on the boxart as well as in the pictures of the ship that I have for references. I used Model Master Enamel in Leather for the decking itself, these will be the basic colors for this job overall.
More to follow, but not quite at this pace as I get to go back to the salt mines for another week of fun and games.
