I built both models out of the box - I guess that's quite a shock for some of you, but it happens.
The final models are quite similar in the overall appearance, the Fujimi Kongo seems to be a bit ahead in terms of detail, but I think some of it is because there is simply more on the 1944 ship than there is on the 1942 ship. All the AAA and radar might just make it appear a bit more detailed. If you check the individual components close up, there isn't much to chose between the two. The 25mm AAA on the Aoshima model is a load nicer, the crane at the main mast comes with a pulley only on the Fujimi model. The vents on the Aoshima deck are molded on, so they are simply poles, while the vents on the Fujimi model are individual, mushroom shaped parts. Planes and boats on the Fujimi are more detailed, too. All in all, there is little to choose between the two. A small malus for the Aoshima kit are the multiple deck joints, which are a lot more visible than on the Fujimi kit. Imho, this more than offsets the infamous casemate shapes of the Kongo.
I've had a lot more fun building the Aoshima kit. The assembly of the Fujimi kit had some lows, and is my biggest grieve with the kit, I remember the Pagoda bridge to have been a pita in particular. No such thing on the Aoshima kit. It's much more simple in construction and also, the parts actually fit. Even some of the more complex, small things go really smooth. Almost perfect.
The biggest downside of the Aoshima kit is the assembly instruction. In fact, it tells you to install binoc on some poles on the uppermost bridge deck. There are extra binocs on the frame, and there are extra poles on the bridge, at lower levels, and on the smoke stack. Nothing more obvious than to put some of the binocs there, makes it look better. However, the assembly instructions don't tell you to do so, and if you were to go by the instructions, you'd end up with a load of silly poles. But that's a minor thing, my biggest issue is the lack of detailed painting instructions. Ok, it's not that difficult, but still, am I supposed to look at the small pictures on the box to know the details? Fujimi tells you exactly which colour to put where and also puts a big poster of the ship into the box, that makes an excellent quick reference on the wall next to the desk.
All in all, I think both models are very good. Personally, I'd rate
80% for Aoshima
70% for Fujimi
A decent assembly simply is more important than a decent assembly instruction.
For folks who like to use pimp their kits, may it be wooden decks or PE, I think there is less to choose between the kits, because taking all the molded on bits and pieces off the Aoshima model won't be much fun, somewhat negating the advantages of the easier and more fun assembly.
