super-duper...esp. the glue-work. What was your technique?
pm sent, now you know...
pe app will look great
Going back to the Nagato....i saw where someone had gotten a spray can of Mr Surfacre 1000 and sprayed it on the hull then sanded down a bit to even it out. That is the method i plan to try
...i just painted the test section to test visablility of the cad lines once paint has been applied. Will let dry and take a couple of pics and post results tonight...
Two other questions...can Mr Surfacer be used in an airbrush? I would think it would tend to clog badly, but I have no idea (and yes, I'm too lazy to go test it myself)
and...would the coarser or finer grit Surfacer be your first choice for this app?
elevation gear added underneath
pic makes the parts look copper. maybe its the dirty mat
Beautiful work! It is interesting what glue has been used for such a clean P.E. job?
Is there a special technique?
