I actually put the two halves of the hull together last night and clamped it up, but when I removed the clamps it had not joined properly, so this morning I put the clamps back on and put lots of liquid cement around the joint. It has been clamped all day and hopefully will be fine by tomorrow.
Next up I started what I like to think of as PE Day.. Almost nothing but PE all day. First up the gun directors..
The actual array took a bit of time to work out how to actuallt bend it. In the end I folded them in the middle first, then using bamboo skewers I bent the round bits to shape. Then I glued them to there supports.
Then I folded up the stands for the aerials and glued them to the top of the directors.
After that I just attached the small antenna on the side and voila! a well detailed gun director.. and I needed four of them for this beasty.
Then I went to these radar aerials which were a lot simpler than the other ones. I used thick CA glue when I attached the aerials to their supports and then stuck them to the PE platform you glue over the kit support.
Next up I started the search radar and this was as far as I got. This one is by far the most difficult as the dish has to be dished.. if you know what I mean. I actuallt cut the flat aerial so I could dish it and get rid of many of the crinkles that appeared around the edge. Eduard recommended using a steel ball, but I don't know many people around here with 1 inch steel balls so I used the rounded end of a screw driver instead. I forgot to anneal it first which probably would have made it much easier. Oh well. I have attached the first part of the support frame to the aerial.
That is as far as I got today.
Thanks for looking.
