Wow, it's been more than a month since my last post. You know you're slacking when you have to search for your own build log. I had hoped to put up more progress photos but I guess DD-448 developed a mind of her own. Finished photos are below (all input is welcome) but here are my parting thoughts:
1 - The Tamiya kit is a great starting point for modeling an early Fletcher. It goes together easily, it's nicely engineered, and the instructions are near idiot-proof. Add an after-market detail set and you've got a really nice model. I just wish Tamiya produce a square bridge version.
2 - I challenged myself to weather this model more aggressively and I'm mostly happy with what I achieved. I'd appreciate input in this area. I was aiming for more discoloration, chipping, etc. below the waterline but that was my initial area of experimentation. When it didn't work out I kept moving. I received the AK Interactive DVD for Christmas so I'll be looking to that for ideas as well.
3 - I attempted a replacement mast out of brass rod and tube but I don't think it was worth the effort. First off, since I used sprue (which didn't put any load on the mast) the brass was overkill. Second, going with brass meant that I had to cut off and reattach all of the small mast details. I ended up with a slightly wonky mast for no real gain. Ugh.
4 - I had a tougher time than expected with the railings. In part this might be because I attached the deckhouses to the model first (normally I don't). I also found the Alliance Modelworks PE to be very fragile. I'm not ham handed and I had a tough time handling it without deforming it. My main problem was dealing with a generic railing set. Maybe I need to go back to school but I struggle to measure and cut railings to length accurately.
