Good luck on the kit surgery Anthony!!
Looking forward to seeing the reworking of your battle group Mardis!! I think if I could get a decent Arizona under my dealt (this is #2) I might have a go at some of the other lady's she set sail with!
Nothing huge in the way of an update, but it's something, right? I managed to dive into the PE a bit. After cutting off all of the features on the various decks of the bridge I sanded them down a bit thinner than what DML had them at. Not only was this done for the thickness of the but the Eduard parts do come in a bit shy on measurement for use with the DML version...not impossible though.
I chose to solder the bridge cabins instead of the CA route. This gives them much more strength and the sanding process smooths thing out nicely I think.
I still have watertight doors and what-have-you but CA will probably be a lot easier than the solder route!
You can see at the back end of the flag deck above, that the PE that needed to be installed there needed a little bit of extra love. I had to attach a small cleat using styrene to the inside on both sides to act as not only a support but a filler for the tail end. I also added a small strip on the underside of the searchlight platforms that stick out as they are suppose to have a little frame on the bottom. I am not too concerned that these were also perforated deck, oh well!
I am betting that a couple of you might notice the two triangular pieces of white stock on the front. The Conning tower, while actually being the wrong size, should sit flush with the front edge and the windshield/splinter shield that goes in from is actually stepped up form the deck. Rather than trying to fashion a .5 mm strip to wrap around the front of the conning tower I chose to just pad it up a little in this section. Once the decks are painted and being this is 1/700 scale, I doubt much will be seen.
A quick mock up is in order. Please bear with the semi-unevenness as these are not glued in place and there is some sanding still needed to the bottom of the PE.
Looking down on the searchlight perches off the flag deck, there is a nipple-shaped protrusion. The railing actually conformed to this shape on the original ship and the Eduard PE is not long enough to go this route.
Fortunately, I have two sets of the DML PE Railing in this kit and one of the railing sets where close enough for the task.
So, there is a ways to go on this and I am sure there will be more pitfalls along the way yet to come! Thanks for tagging along!!!
