Sunday, June 14, 2015 - 12:58 AM UTC
Making things easier and taking tube connecting to a whole new level! Uschi van der Rosten releases a new set of TUCONN T-type connectors for tube and rod stock.
TUCONN Connector pieces for tubing and rod
The Photo Etch Set Includes - 72 connectors, 24 each for 1.0mm, 1.2mm and 1.4mm tubing
MSRP - 8,90 € / $9.99US (+shipping)
TUCONN is a photo etch piece, allowing you to connect tubing and rod without having to solder it. It re-creates a 3D joint, just as it often can be seen on the real thing. The first release for today is the T-Type, allowing you to connect tubes T-wise.
Available now at Uschi van der Rosten
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 2,943 TIMES.
