1⁄700
Monday, October 15, 2007 - 12:42 PM UTC
Delphis Models announces the release of their latest resin ship, Italian Navy Frigate Orizzonte. This 1/700 resin kit is of the new Horizon Common New Generation Frigate (CNGF), a multi-national collaboration with France and Italy. This kit will retail for $85.24.
Ship history
The Horizon Common New Generation Frigate (CNGF) is a multi-national collaboration to produce a new generation of anti-air warfare frigates. Originally an alliance of Britain, France and Italy, the project is now a French/Italian effort following the withdrawal of Britain due to differing requirements. It is named Orizzonte in Italian and Horizon in French.
France, Italy and the UK issued a joint requirement in 1992 after the failure of the NAT Frigate Replacement (NFR-90) project. The resulting CNGF program consisted of the Horizon frigate and its Principal Anti Air Missile System (PAAMS).
Problems emerged almost immediately: the primary problem was that of differing requirements: France wanted Anti-Air Warfare (AAW) escorts for its aircraft carriers, but only a limited range was necessary due to the self-defence capability of the Charles De Gaulle. Italy too required only close range capabilities, as in its home waters of the Mediterranean Sea the ships would operate under Italian Air Force cover. The Royal Navy, however, required more capable ships which could throw a large defensive "bubble" over a fleet operating in hostile areas. The compromise which largely solved this problem was the adoption of a standard radar interface which allowed France and Italy to install the EMPAR multi-function radar and the UK to install the more capable SAMPSON radar - the SAMPSON radar has a higher data rate and adaptive beam forming allows a greater multi-tracking capability, long-range detection of low-RCS targets, a lower false-alarm rate, and overall higher tracking accuracy.
1995 saw the establishment of an International Joint Venture Company (IJVC) compromising the national prime contractors, DCN (France,) GEC-Marconi (UK) and Orizzonte (Italy). In the period 1995-1996 significant arguments, changing requirements and technological problems led to the slippage of the in-service-date of the frigates to around 2006.
In early 1997 a disagreement emerged as to the choice of Vertical Launch System (VLS) for the PAAMS' MBDA Aster missiles. France and Italy favoured the European SYLVER launcher, while the UK was leaning toward the American Mk 41 - capable of firing the Tomahawk Land Attack Missile. This issue was eventually resolved when the SYLVER launcher was selected by the PAAMS development team.
On 26 April 1999 the UK announced that it was withdrawing from the CNGF project to pursue its own national design. The Financial Times summarised the main disagreements between the partner countries; the UK wanted a large frigate which could patrol large areas such as the Atlantic, compared to France's desire for smaller aircraft carrier escorts and Italy's intention to use them in the Mediterranean; Secondly the UK wanted the ships with a wide-area defence capabiltiy, able to protect large numbers of ships rather than just protection from missiles targeted in the frigate's general direction; Finally the UK's desire to see Marconi appointed as prime contractor was accepted by France, but only in return for DCN being given the role as prime contractor for the combat management system. The UK, which wished to see a BAe-led consortium given this role, would not accept this.
Summing up the changes from the original specification the UK's Chief of Defence Procurement is reported to have said "it's not common and it's not a frigate!". The resulting Type 45 destroyer is armed with the PAAMS missile system and has benefited from investment in the Horizon project.
France and Italy have continued their collaboration under the Horizon project, ordering two ships each which will also deploy the PAAMS missile system. The first ship of the series, the French Forbin, was launched on the 10th March 2005.
The French Navy has ordered two units (Forbin and Chevalier Paul). Two more units were to be ordered later to replace the Cassard class frigates, but the plan was replaced by two anti-air FREMM multipurpose frigates.
The Marina Militare also ordered two units, Andrea Doria and Caio Duilio, to replace Audace and Ardito.
France and Italy have launched a new generation of multimission ships, the FREMM multipurpose frigates, using the same company structure as the Horizon project.
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 6,912 TIMES.
| Delphis Models Reviews | MORE |
| MMI San Giusto by David J. Salvin | of 1 ratings, 100% found this helpful | |
