Saturday, February 16, 2008 - 05:51 PM UTC
The Virginia Class new attack submarine is an advanced stealth multi-mission nuclear-powered submarine for deep ocean anti-submarine warfare and littoral (shallow water) operations.
Although the Seawolf submarine was developed to provide an eventual replacement for the US Navy Los Angeles Class submarines in combating the Soviet forces, the prohibitive unit cost and changing strategic requirements led to the US Navy defining a smaller new-generation attack submarine.
The Electric Boat division of General Dynamics, Connecticut is the lead design authority for the Virginia Class. General Dynamics Electric Boat has built the first of class – Virginia (SSN 774) and Northrop Grumman Newport News the second – Texas (SSN 775).
The subsequent vessels will be: Hawaii (SSN 776) and New Hampshire (SSN 778), being built by Electric Boat, and North Carolina (SSN 777) and New Mexico (779), being built by Newport News.
The US Navy's total requirement is for 30 of the class. It placed a bulk-buy contract for the first five ships and, in January 2004, placed a multi-year contract for the following five.
Virginia was laid down in September 1999, launched in August 2003 and commissioned in October 2004. It is undergoing a three-year operational evaluation before operational deployment. Texas was launched in April 2005, delivered in June 2006 and commissioned in September 2006. The keel for Hawaii was laid in August 2004, it was launched in June 2006 and commissioned in May 2007.
North Carolina was launched in May 2007 and delivered in December 2007, and will be commissioned in April 2008. New Hampshire will be delivered in 2010 and New Mexico in 2011. SSN 780 began construction in December 2004 but is as yet unnamed.
DESIGN
The engineering teams and the design and build teams at Electric Boat in partnership with the Naval Sea Systems Command, NAVSEA, of the US Navy have used extensive CAD/CAE simulation systems to optimise the design of the submarine. The hull size is length 377ft by beam 34ft and the displacement is 7,300t dived, which is smaller than the more expensive Seawolf Attack Submarine with displacement 9,137t dived.
The hull structure contains structurally integrated enclosures, which accommodate standard 19in and 24in width equipment for ease of installation, repair and upgrade of the submarine's systems.
The submarine is fitted with modular isolated deck structures, for example the submarine's command centre will be installed as one single unit resting on cushioned mounting points. The submarine's control suite is equipped with computer touch screens. The submarine's steering and diving control is via a four-button, two-axis joystick.
The noise level of the Virginia is equal to that of the US Navy Seawolf, SSN 21, with a lower acoustic signature than the Russian Improved Akula Class and fourth-generation attack submarines. To achieve this low acoustic signature, the Virginia incorporates newly designed anechoic coatings, isolated deck structures and a new design of propulsor.
Goodrich is supplying high-frequency sail array acoustic windows and composite sonar domes.
COMMAND SYSTEM
The Command and Control Systems Module (CCSM) is being developed by a team led by Lockheed Martin Naval Electronics & Surveillance Systems – Undersea Systems (NE&SS-US) of Manassas, Virginia. It will integrate all of the vessel's systems – sensors, countermeasures, navigation, weapon control, and will be based on open system architecture (OSA) with Q-70 Colour Common Display Consoles.
Weapon control will be provided by Raytheon with a derivative of the CCS Mk 2 combat system, the AN/BYG-1 combat control system, which is also being fitted to the Australian Collins Class submarines.
The Virginia has two mast-mounted Raytheon Submarine High Data Rate (Sub HDR) multi-band satellite communications systems that allow simultaneous communication at Super High Frequency (SHF) and Extremely High Frequency (EHF).
WEAPON SYSTEMS
The submarine is equipped with 12 vertical missile launch tubes and four 533mm torpedo tubes. The vertical launching system has the capacity to launch 16 Tomahawk Submarine-Launched Cruise Missiles (SLCM) in a single salvo.
There is capacity for up to 26 Mk 48 ADCAP Mod 6 heavyweight torpedoes and sub harpoon anti-ship missiles to be fired from the 21in torpedo tubes. Mk 60 CAPTOR mines may also be fitted.
An integral lock-out / lock-in chamber is incorporated into the hull for special operations. The chamber can host a mini-submarine, such as Northrop Grumman's Oceanic and Naval Systems Advanced SEAL Delivery System (ASDS), to deliver special warfare forces such as Navy Sea Air Land (SEAL) teams or Marine reconnaissance units for counter-terrorism or localised conflict operations.
COUNTERMEASURES
Virginia will be fitted with the AN/WLY-1 acoustic countermeasures system being developed by Northrop Grumman, which provides range and bearing data, and the mast-mounted AN/BLQ-10 Electronic Support Measures (ESM) system from Lockheed Martin Integrated Systems.
AN/BLQ-10 provides full spectrum radar processing, automatic threat warning and situation assessment.
SENSORS
The Virginia Class sonar suite will include bow-mounted active and passive array, wide aperture passive array on flank, high-frequency active arrays on keel and fin, TB 16 towed array and the Lockheed Martin TB-29A thinline towed array, with the AN/BQQ-10(V4) sonar processing system. A Sperry Marine AN/BPS-16(V)4 navigation radar, operating at I-band, is fitted.
The submarines will have two Kollmorgen AN/BVS-1 photonic masts, rather than optical periscopes. Sensors mounted on the non-hull-penetrating photonic mast include LLTV (Low-Light TV), thermal imager and laser rangefinder. The mast is the Universal Modular Mast developed by Kollmorgen and its Italian subsidiary, Calzoni.
The Boeing LMRS Long-term Mine Reconnaissance System will be deployed on the Virginia Class. LMRS includes two 6m autonomous unmanned underwater vehicles, an 18m robotic recovery arm and support electronics.
Northrop Grumman Electronic Systems is supplying the LightWeight, Wide-Aperture Array (LWWAA) system based on fibre-optic arrays, instead of traditional ceramic hydrophone sensors. LWWAA is a passive ASW sonar system which consists of three large array panels mounted on either side of the submarine's hull.
PROPULSION
The main propulsion units are the GE pressure water reactor S9G, designed to last as long the submarine, two turbine engines with one shaft and a United Defense pump jet propulser, providing 29.84MW. The speed is over 25kt dived.
Specifications - NSSN Virginia Class Attack Submarine, USA
Crew-134
Length-377ft
Beam-34ft
Displacement, Submerged-7,800t
Performance
Speed (Dived)-Over 25kt
Diving Depth-800ft
Weapon Systems
Cruise Missiles-12 x vertical launch systems, tubes for Tomahawk SLCM
Anti-ship Missile-Sub Harpoon
Torpedo Tubes-4 x 21in
Torpedoes-Mk 48 ADCAP (advanced capability)
Mines-Mk 60 CAPTOR
Propulsion
Engine-1 x GE PWR S9G
Power 29.84MW (40,000hp)
DESIGN
COMMAND SYSTEM
WEAPON SYSTEMS
COUNTERMEASURES
SENSORS
PROPULSION
Crew-134
Length-377ft
Beam-34ft
Performance
Diving Depth-800ft
Weapon Systems
Mines-Mk 60 CAPTOR
Propulsion
THIS STORY HAS BEEN READ 12,684 TIMES.
Photos
Click image to enlarge
To achieve a low acoustic signature, the Virginia Class design features anechoic coatings, isolated deck structures and a new design of propulsor.
Virginia (SSN 774) submarine at Norfolk, Virginia Naval Station, where it was commissioned in October 2004.
Launch of Texas (SSN 775) in April 2005 at Northrop Grumman Newport News shipyard in Virginia. It was commissioned in September 2006.
The Virginia (SSN 774) submarine alongside at the General Dynamics Electric Boat yard at Groton, Connecticut.
The Virginia Class is designed for the mission requirements of the post-Cold War era.
The Virginia (SSN 774) submarine is an advanced stealth multi-mission nuclear powered submarine for anti-submarine warfare and littoral operations.
Texas (SSN 775) being moved to the floating dry dock.
Virginia (SSN 774) sailing into Portsmouth, Virginia.
Bow of Hawaii (SSN 776) under construction
| USN Reviews | MORE |
