1⁄700
Thursday, November 20, 2003 - 12:35 PM UTC
Tamiya has re-issued the Japanese Light Cruiser Kumano in 1:700 waterline form. I am unsure of wether this is an exact re-issue or has been re-tooled in any way. The old kit number was 31313 and the new number is 31344.
This is from the Tamiya site:
About the Japanese Light Cruiser Kumano
A main characteristic of the heavily armored Mogami class cruisers was the use of weight saving techniques. This, however, resulted in concerns for the ships overall strength and stability. The Kumano, the last Mogami cruiser completed in 1937, was subsequently fitted with a large bulge, and the upper deck was built narrower and lower than the first two Mogami cruisers. The Kumano was originally fitted with 15.5cm triple guns, with a speed of 920m/sec., a max. range of 27,400m and a projection angle up to 55 degrees. These 15.5cm triple guns were highly respected by artillery experts. The Kumano participated in many battles during WWII including the Battle of Midway, the Battle of the Eastern Solomons, and the greatest naval battle of WWII, the Battle of Leyte Gulf, before suffering a simultaneous torpedo attack causing it to sink in Santa Cruz Bay in 1944.
About The Model Japanese Light Cruiser Kumano plastic assembly kit.
1/700 scale, Overall length: 286.5mm, Overall width: 36.5mm.
The graceful form of the Kumano has been accurately replicated.
Kumano's characteristic structures have been accurately reproduced.
The hull has been divided in two halves in order to reproduce the finest details.
The layout of the rear flight deck with rails and turntables has been sharply represented.
The main turrets can rotate after completion via polycap.
Equipment such as armament including 12.7cm gun turrets or triple tube torpedo launchers, main mast, aircraft crane and catapults are accurately reproduced.
No one has rated this yet.
THIS STORY HAS BEEN READ 5,373 TIMES.
| Tamiya, Inc. Reviews | MORE |
| CVN-65 USS Enterprise by Dariush | of 1 ratings, 100% found this helpful | |
| Tamiya 1/700 Z Class (Z37-39) by Scott Espin | of 5 ratings, 100% found this helpful | |
| IJN Mogami 1/350 by Jim Adams | of 7 ratings, 100% found this helpful | |
| IJN Mogami Aricraft Cruiser by Anthony Kochevar | of 7 ratings, 100% found this helpful | |
| USS Fletcher by Jay Massey | of 3 ratings, 100% found this helpful | |
| IJN Sakura by Jacob Walker | of 2 ratings, 100% found this helpful | |
| Bogue Class Carrier by Martin Ramsden | of 2 ratings, 100% found this helpful | |
