Friday, March 28, 2008 - 04:21 AM UTC
South Africa placed a contract for three Type 209/1400 submarines in July 2000 on Howaldtswerke-Deutche Werft (HDW) and Thyssen Nordseewerke. The Type 209/1400 displaces 1,450t surfaced and 1,600t dived. The Type 209/1400 submarines replace the French-built Daphne Class submarines, SAS Spear, SAS Assegai and SAS Umkhonto which were decommissioned in 2003.
The first submarine, SAS Manthatisi (S101), was built by Howaldtswerke at Kiel. It was launched in June 2004 and commissioned in November 2005. The second and third submarines were built by Thyssen Nordseewerke in Emden. The SAS Charlotte Maxeke (S102) was launched in May 2005 and commissioned in March 2007. The third submarine, SAS Queen Modjadji (S103), was launched in 2006 and will be commissioned in 2008.
The submarines' homeport is Simon's Town naval base in Cape Town.
The submarines are named after powerful South African women. SAS Manthatisi is named after the female warrior chief of the Batlokwa tribe. SAS Charlotte Maxeke is named after the female political activist who campaigned for equality in the early 20th century. SAS Queen Modjadji is named after the South African rain queen.
12 countries operate the Type 209 submarine in five variants. The suffix denotes the tonnage displacement of the submarine: Type 209/1100 in service with the Hellenic Navy; Type 209/1200 (Greece, Turkey, Argentina, Peru, Columbia, Venezuela, Indonesia, South Korea), Type 209/1300 (Ecuador), Type 209/1400 (Turkey, Chile, Brazil, Greece and South Africa) and Type 209/1500 (India).
MANTHATISI CLASS PERFORMANCE
The submarine has a crew of 30. The hull has a length of 62m, breadth of 7.6m and height of 5.8m. It has a maximum diving depth of 250m.
The Type 209/1400 submarine has a maximum speed of 10kt surfaced and 22kt dived.
COMMAND AND CONTROL
The Atlas Elektronik ISUS 90 integrated sensor underwater system provides fire control for the torpedoes. In addition to automatic fire and weapon control, it performs automatic sensor management as well as navigation and support functions.
WEAPONS
There are eight 533mm bow torpedo tubes and the submarine can carry up to 14 torpedoes.
SENSORS
The submarine is fitted with a non-hull-penetrating mast supplied by Carl Zeiss Optronics. The mast integrates an optronic sensor with a high-definition resolution colour TV camera and third generation thermal imager. The cameras are gyroscopically stabilised in elevation and azimuth.
The sensor assembly is installed in a retractable unit outside the pressure hull of the submarine. The observation and operation of the mast are controlled on a console. The optronics mast system contains fully automatic functions for very fast surveillance and observation so the period of mast exposure above the surface is extremely short.
The surface search radar operates at I-band. The sonar suite includes an Atlas Elektronik CSU 90 hull-mounted passive and active search-and-attack sonar and flank sonar arrays.
COUNTERMEASURES
The submarine is equipped with a Saab Grintek Avionics electronic support measures system.
The submarine's ELINT electronic intelligence system is the Saab S/UME-100 tactical electronic support measures which provides electronic intelligence analysis and amplitude direction finding capability.
The S/UME-100 comprises the ESM antenna, the radar warning receiver antenna, a signal distribution unit and an electronic warfare controller.
The S/UME-100 tactical ESM antennas interface to the optronics mast and attack periscope.
PROPULSION
The submarines are fitted with a diesel electric propulsion system based on four MTU 12V 396 diesel engines delivering 2.8MW, with four alternators and one Siemens 3.7MW motor, driving a single shaft.
Specifications - SSK Manthatisi Class (Type 209/1400) Attack Submarine, South Africa
Crew-30
Length-62m
Hull Height-5.8m
Displacement-1,450t (surfaced) 1,600t (dived)
Diving Depth-250m
Performance
Maximum Surface Speed-10kt
Maximum Dived Speed-22kt
Weapon Systems
Bow Torpedo Tubes-8
Bow Torpedo Tube Diameter-533mm
Torpedoes-14
Propulsion
Type-Diesel Electric
Diesel Engines-4 x MTU 12V 396
Diesel Engine Power 2.8MW
Alternators-4
Siemens Motor 3.7MW
Shaft-1
COMMAND AND CONTROL
WEAPONS
SENSORS
COUNTERMEASURES
PROPULSION
Crew-30
Length-62m
Hull Height-5.8m
Diving Depth-250m
Performance
Weapon Systems
Bow Torpedo Tubes-8
Torpedoes-14
Propulsion
Alternators-4
Siemens Motor 3.7MW
Shaft-1
THIS STORY HAS BEEN READ 17,070 TIMES.
Photos
Click image to enlarge
First of class SAS Manthatisi (S101) engaged in training exercises in European waters prior to sailing to South Africa.
Three Type 209/1400 attack submarines, the SSK Manthatisi Class have been built for the South African Navy.
The Type 209/1400 submarine is in service with Turkey, Chile, Brazil, Greece and South Africa. The Brazilian Navy operates three Tupi Class Type 209/1400 submarines.
12 countries operate the Type 209 submarine in five variants. The South Korean Chang Bogo submarine is Type 209/1200.
The Type 209/1400 submarines have a diesel electric propulsion system, based on four MTU 12V 396 diesel engines delivering 2.8MW.
SAS Manthatisi (S101) arrived at its home port of Simon's Town in April 2006
Cutaway diagram of the Type 209/1400 submarine.
SAS Manthatisi (S101), escorted by SAS Drakensburg, en route to South Africa.
| South African Navy Reviews | MORE |
